Valve spring removal
Old Dec 23, 2001 | 10:24 PM
samiam's Avatar
Default Valve spring removal
Does any one know what valve spring compressor to use on pr3 heads? i tried 2 of them and it doesnt work not enough space .
Old Dec 23, 2001 | 10:42 PM
RedlinedVTEC's Avatar
Default Re: Valve spring removal (samiam)
Well for removal I like the old Oxygen sensor socket and hammer method myself. Very quick and painless. Install is a different ballgame. Get the snap on valve spring compressor and the attachment to go on the end. Not sure on the part numbers.
Old Dec 23, 2001 | 11:42 PM
Backyard Speical's Avatar
Default Re: Valve spring removal (RedlinedVTEC)
the Oxygen sensor socket and hammer would work great.
Old Dec 23, 2001 | 11:54 PM
rainforest's Avatar
call your local snap on dealer for more info on it. They make valve spring compressors for like all cars and i know they make them for hondas. i have one.
Old Dec 24, 2001 | 12:56 AM
SpeedracerS4's Avatar
Try this https://honda-tech.com/zerothread?id=98920
Old Dec 24, 2001 | 11:15 AM
Quick 200k Mile Motor's Avatar
Default Re: Valve spring removal (SpeedracerS4)
i do not understand the o2 sensor socket and hammer thing
wouldnt you use a hard rubber mallet instead?
what do you do.. hammer the socket on top the retainer?
what about the valve keeper.. what happens to it?
about installation.. what do you guys use to obtain the recommended installed height? i heard this is important for performance & reliability
dial calipers?
Old Dec 24, 2001 | 03:55 PM
Default Re: Valve spring removal (Quick 200k Mile Motor)
I just put the o2 sensor socket on top of the retainer and hit it with a claw hammer. The valve keepers just pop off, just keep track of them as you do each valve.
JDM_SOHC
Mar 23, 2012 01:42 PM
99EletronblueSI
Nov 8, 2004 08:24 PM
importlegions
Jul 15, 2004 08:53 PM
inspyral
Mar 21, 2003 05:51 AM
