DSM Injectors, clips, resistor boxes.. clear it up for me!
Since the search function is down right now, I need a little clarification on what to use on my boosted OBD2 y7/y8 mini me in terms of injectors, clips, and resistor boxes.
I know that the DSM injectors are low-impedance and they require a resistor box to run them. However, which clips do I use (remember I'm OBD2)? I plan on using DSM 390cc or 450cc.... I've heard of modifying the stock ones in order for them to fit on the DSM's, but I believe this is only for OBD1 hondas. Can I modify my current ones?
Also, how exactly do I wire up the resistor box? Not sure exactly what it came out of, but this is what I got:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm98civic »</TD></TR><TR><TD CLASS="quote">Since the search function is down right now,</TD></TR></TABLE>
Good excuse. . .
JK.
Good excuse. . .
JK.
You don't need that much stuff...
OBD1 injector clips
Knife
Electrical tape
And bore out your injector seals too
Check out the explanation on http://www.hondata.com in the tech section about injector wiring, it's real good.
OBD1 injector clips
Knife
Electrical tape
On mine i used obd 0 clips and they plug right into the dsm injectors, they plugged right in no problem. then on the box you can get the plug or just cut and splice, 4 same colored wires are injector power doesnt matter order or anything, the the single wire left is power, use one of the black and yellows from the empty plug one the drivers side engine harness that will be your power and your done.
