valve spring removal
Old Dec 23, 2001 | 09:59 PM
samiam's Avatar
Default valve spring removal
Does any of you guys know what valve spring remover to use on the pr3 heads? I tried 2 different types to no avail. Do i need to remove the rocker arms? I'll try and ask the guys at my local machine shop. If i find out how i'll post it on the board.
Old Dec 23, 2001 | 11:10 PM
Redline130's Avatar
Default Re: valve spring removal (samiam)
Go to http://www.toolwarehouse.net , they have a valvespring compressor similar to the Snap-On one. Yeah, you have to remove the rocker arms to get to the springs. Do a search on this topic, there have been a few in-depth threads about working on valvesprings. HTH.
cyber13
[Modified by cyber13, 12:12 AM 12/24/2001]
Old Dec 23, 2001 | 11:15 PM
samiam's Avatar
Default Re: valve spring removal (cyber13)
thanks man I see your from the big island.. hows the scene down there?
Old Dec 23, 2001 | 11:20 PM
Redline130's Avatar
Right now not too much going on. Track won't be open until January at the earliest. Sucks. Everyone's pretty much just street racing all over the island. BTW, the part # for the tool is SP 91400. I have one, and it works good.
cyber13
Old Dec 24, 2001 | 04:52 AM
badCRX's Avatar
New User
I have done a number of valve spring swaps with cam swaps and learned that it is not necessary to remove the rocker arms. I always pulled the intake and exhaust side ones back and put a rubber band around all of them for each cylinder. The valve spring remover I had had enough clearance where they weren't in the way.
JDM_SOHC
Mar 23, 2012 01:42 PM
HOMEMADEPOWER
Jan 31, 2011 04:07 PM
Littlegreend15
Jul 1, 2005 08:31 AM
importlegions
Jul 15, 2004 08:53 PM
inspyral
Mar 21, 2003 05:51 AM
