Turbo vs. All Motor which is better for my b16a2?
Old Nov 7, 2004 | 11:03 AM
BLKCivicPorscheStyle*'s Avatar
Default Turbo vs. All Motor which is better for my b16a2?
The search server was "temporarily unavailable" when I posted this so sorry if there is already a post for this if so please direct me.
Doing a b16 swap and looking to get about 300hp out of it. But which is the better road to travel? If i went turbo I would go greddy 18g (please dont tell me go drag or revhard bc I wont) If i went all motor I would do all the internals individual throttle bodies and Im not sure what else.
So heres the question
All motor or turbo better an why? whats involved with both what would I need?
Take into acount the cost. Im thinking turbo may be better but how much more is it going to cost me? and i know you have to run higher octane gas in a turbo set up what about all motor that could be even more money?
Also take into acount relieability. This will be a daily driver so I want something reliable and that isnt going to get me killed bc of blowing up ect.
I am somewhat of a noob when it comes to motors so im hear to learn. school me! thanks everyone
Old Nov 7, 2004 | 11:05 AM
ieatrice's Avatar
Default Re: Turbo vs. All Motor which is better for my b16a2? (BLKCivicPorcheStyle*)
I got a b16 sir2 i wanna know the same thing bump
Old Nov 7, 2004 | 11:09 AM
slow94coupe's Avatar
Default Re: Turbo vs. All Motor which is better for my b16a2? (ieatrice)
300hp on a daily driver wow either way its gonna be expensive
Old Nov 7, 2004 | 11:10 AM
originalsin's Avatar
building all motor will cost more and you wont get as much hp, but turboing is cheaper and will get u better power gains, with a b16 i recogmend using a smaller turbo, like a smaller t3/t4 or maybe even a t3 for a cheap set up, smaller displacement = more lag, do research on yahoo
Old Nov 7, 2004 | 11:12 AM
Ricey McRicerton's Avatar
Default Re: (originalsin)
You aernt going to make 300whp on a N/A build that is anywhere near streetable.
300whp out of boost will be much easier.
Old Nov 7, 2004 | 11:14 AM
cost doesnt matter all that much im trying to keep it in the ballpark of 5k i was thinking that if i got a turbo i should replace internals anyway so would it still be as expensive?
reminder turbo would be greddy 18g
all motor would be ???? help me out
Old Nov 7, 2004 | 11:16 AM
Civicse's Avatar
i say go all motor. if u do it urself u'll learn a lot more by rebuilding ur engine rather than just bolting on a turbo.
Old Nov 7, 2004 | 11:17 AM
Default Re: (BLKCivicPorcheStyle*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKCivicPorcheStyle* &raquo;</TD></TR><TR><TD CLASS="quote">cost doesnt matter all that much im trying to keep it in the ballpark of 5k i was thinking that if i got a turbo i should replace internals anyway so would it still be as expensive?
reminder turbo would be greddy 18g</TD></TR></TABLE>
You almost have no choice if you are looking for 300 whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKCivicPorcheStyle* &raquo;</TD></TR><TR><TD CLASS="quote"> all motor would be ???? help me out</TD></TR></TABLE>
Non existant. To get 300whp out of a B16A2 is going to be much more involved and damn near impossible.
DerekHOOD's Avatar
you will get more power with the turbo and it will be cheaper
Old Nov 7, 2004 | 11:18 AM
i think you should just build the motor then if its not enough boost it. it sounds like moneys not a problem for you.
Old Nov 7, 2004 | 11:19 AM
alloutmotor's Avatar
you want 300hp daily or when you turn up the boost,
putting together a nice t3/t04e set up should get you to 300hp without tons of lag,
Old Nov 7, 2004 | 11:20 AM
Default Re: (Ricey McRicerton)
i guess its not so much hp im looking for but torque. I just want to be able to contest against mustangs and some others. I want my tires to chirp on every shift
Old Nov 7, 2004 | 11:21 AM
Del Sizzle's Avatar
You're not going to get 300 all motor and be streetable. If you think we're wrong, go to a import drag event and what the all motor class. Listen to there motors. The only way you could pull it off is if you're planing on dropping in a NSX motor
Old Nov 7, 2004 | 11:22 AM
if you want torque why are you using a b16?
Old Nov 7, 2004 | 11:23 AM
Default Re: (Del Sizzle)
ok then i guess that will do it. What kind of horsepower could i get on a streetable motor and what would I have to run?
2000EM1's Avatar
Default Re: Turbo vs. All Motor which is better for my b16a2? (slow94coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow94coupe &raquo;</TD></TR><TR><TD CLASS="quote">300hp on a daily driver wow either way its gonna be expensive</TD></TR></TABLE>
it'll be MUCH more expensive and there's no guarantee you're going to get 300 crank hp out of a b16 without turning it into a 2 liter
Old Nov 7, 2004 | 11:24 AM
Del Sizzle's Avatar
If you want more torque, start with getting a H22 motor.
Default Re: (slow94coupe)
its an easy swap what do you suggest?
Old Nov 7, 2004 | 11:25 AM
Default Re: Turbo vs. All Motor which is better for my b16a2? (revolution8k)
i would say go lsvtec bored to a 2.0 but thats what im building so dont do it
how hard of a swap is that into a 99 civic ex? any links you can point me to?
Old Nov 7, 2004 | 11:26 AM
what car is this going into?
Old Nov 7, 2004 | 11:27 AM
Del Sizzle's Avatar
Any K,B,or H series swap is not hard. Their is a ton of info here on honda-tech.
Old Nov 7, 2004 | 11:28 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
Non existant. To get 300whp out of a B16A2 is going to be much more involved and damn near impossible.</TD></TR></TABLE>
Exactly right..... $5000 wouldn't even come close to getting you near 300hp on a B16 (NA), even the Mr Gasket "The Beast" motor for $10,000 doesn't pump out 300hp so you might as well forget the possibilty of going the NA route NOW.
As for turbo, all you'd need internally is a set of rods, a block guard and a set of pistons, a tuning system like Hondata and you'd be well on your way to a solid and reliable 300hp on boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by originalsin &raquo;</TD></TR><TR><TD CLASS="quote"> smaller displacement = more lag </TD></TR></TABLE>
This isn't really a true statement if the turbo is sized correctly.
Del Sizzle's Avatar
Search H22a, Archived content
Old Nov 7, 2004 | 11:32 AM
Default Re: (00Red_SiR)
sounds good I think thats the rout I will go then!
