Polyurethane Motor Mounts (not inserts)
Old Dec 23, 2001 | 09:33 PM
HKxBlur's Avatar
Default Polyurethane Motor Mounts (not inserts)
I'm having a tough time finding info on the poly mounts for the Integra.. Not the lower mount/tranny mount inserts, but the upper motor mounts.. Can anyone provide a part number for these? Thanks so much..
Old Dec 24, 2001 | 05:09 AM
JCushing's Avatar
Default Re: Polyurethane Motor Mounts (HKxBlur)
hasport has the back mount. entire back mount (poly) is like 175 i think
Old Dec 24, 2001 | 04:33 PM
HKxBlur's Avatar
Default Re: Polyurethane Motor Mounts (JCushing)
from 'chiangm"s post of his car, here's a pic of the mount I am trying to get ahold of:
http://www.geocities.com/hkxjaybee/motor_mount.htm
Any info on it would be greatly appreciated!
[Modified by HKxBlur, 1:42 AM 12/25/2001]
Old Dec 24, 2001 | 06:15 PM
JDM-EG6's Avatar
New User
those mounts are made by prothane. you can order it through jcwhitney.com thats where i ordered it from....if you order es bushings you do not get those but the es bushings contain all of the flex mounts (two front lower and rear) the prothane covers the two upper and the rear) i hope this helps btw: (part number at jcwhitney.com is 47ZX2058A)
Old Dec 24, 2001 | 06:22 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Polyurethane Motor Mounts (JDM-EG6)
so these "inserts" from prothane are to be used in addition to or without the use of the e.s. inserts... right? The e.s. kit doesn't have inserts for these mounts, correct? Is their much of a difference once you put them in, or is it barely noticeable?
Old Dec 25, 2001 | 11:32 PM
HKxBlur's Avatar
JDM, the photo of that part number at JCWhitney is not what I want.. I'm assuming u bought these with the part number and not the pic.. The pic is what I already have (the lower front mounts and the upper rear trans)..
http://www.prothane.com/Main_Menu/Wh...hat_s_new.html
The second pic is what I need, is this the JCW part number u supplied? Hopefully u can clear that up.. thx man
I sent them an email, hopefully they respond soon..
[Modified by HKxBlur, 8:33 AM 12/26/2001]
Old Dec 26, 2001 | 12:48 PM
HKxBlur's Avatar
I found the Prothane part numbers for exactly what I need:
8-501 - Left upper (driver side)
8-502 - Right upper (pass side)
OR
8-1904 - Both of the above AND firewall/trans mount..
Thanks all for your help
Old Dec 27, 2001 | 10:00 AM
GQ 05YellowEVO8's Avatar
i need one
rocketfuelcerx
Apr 8, 2005 11:53 AM
dunkd
Feb 27, 2005 08:52 PM
Maengelito
16
Dec 5, 2004 07:07 AM
Clabbe
Jul 15, 2004 06:43 PM
ragejed
May 18, 2002 06:56 PM
