whats better.....
Old Dec 23, 2001 | 08:08 PM
-Darren-'s Avatar
Default whats better.....
4-1 or 4-2-1 header? and why?
Old Dec 23, 2001 | 08:09 PM
clean's Avatar
New User
Default Re: whats better..... (lynnheart)
4-2-1 cause i said so, homo. scc did a review of a **** loud of headers and the ceramic greddy tri y came out the top get it
Old Dec 23, 2001 | 08:11 PM
icyballa3's Avatar
Default Re: whats better..... (clean)
4-2-1 makes better bottom end but loses top end, 4-1 does top end well
Old Dec 23, 2001 | 09:06 PM
kefka's Avatar
Default Re: whats better..... (icyballa3)
4-1, cause top end rules and if youre sporting b series youll want a nice strong top end to shove that vtec in anybodies face...
Old Dec 24, 2001 | 04:44 PM
icyballa3's Avatar
Default Re: whats better..... (madeinjapan)
well said, but you gotta have that bottom end to get to vtec (or you could go with the 6000 rpm clutch drops the motorex boys do!)
Old Dec 24, 2001 | 09:51 PM
mojoGSR92's Avatar
I answered a similar question here before:
https://honda-tech.com/zerothread?id=101179
4-1
-Less ground clearance
-More top end power
-Losses in bottom of powerband
4-2-1
-Stronger midrange powerband
-Less top end than 4-1 design
-More ground clearance
Old Dec 24, 2001 | 09:58 PM
EG8R's Avatar
Default Re: whats better..... (mojoGSR92)
I'm curious about this ground clearance. What makes it different?
[Modified by mr. skelly, 10:59 PM 12/24/2001]
Old Dec 24, 2001 | 10:00 PM
mojoGSR92's Avatar
Default Re: whats better..... (mr. skelly)
The reason he PROBABLY mentioned safety is because a 4-1 header doesn't allow as much ground clearance. A 4-2-1 header only has to fit 2 pipes under the oil pan/cross-member (on my car anyways) while a 4-1 header fits 4 pipes under the oil pan/cross-member. This means if your car is "slammed to dah grizzound y0," you will be more likely to damage it.
I spoon fed you the link, and you couldn't even read the thread to understand what I meant.
Old Dec 24, 2001 | 10:05 PM
DragII's Avatar
4-2-1 is what you want if unless you are building an all out track car.
better midrange, decent top end, with out sacrificing anything down low
Old Dec 24, 2001 | 11:34 PM
Mista Bone's Avatar
D Tranny Guru
4-2-1 properly built.
Gotta see SMHS (?) or Hytech to get one though.
Old Dec 25, 2001 | 11:32 AM
B18C-EJ1
Guest
Posts: n/a
Greddy doesn't make a ceramic header.
As for 4-1 or 4-2-1, I'd say 4-2-1 if you want more midrange HP/TQ, 4-1 if you want top end HP/TQ
DARKTEG_
Sep 3, 2006 08:30 AM
JDM00SI
Aug 21, 2004 11:02 PM
jdmCivic925
Aug 3, 2004 04:03 PM
allicedout
Jun 24, 2004 06:51 AM
