b16 tranny
Old Nov 6, 2004 | 06:48 PM
quietzone's Avatar
Default b16 tranny
my tranny won't go into gear but the car still turns on is that the clucth or is the tranny gone?
Old Nov 6, 2004 | 07:48 PM
quietzone's Avatar
Default Re: b16 tranny (quietzone)
any1
Old Nov 6, 2004 | 07:51 PM
=GAME='s Avatar
could be a bent shift fork, or clutch, pressure plate not align right.
is this a stock motor? anything done to it recently?
Old Nov 6, 2004 | 07:54 PM
quietzone's Avatar
Default Re: b16 tranny (=GAMEOVER=)
not stock b20vtec i just replaced the pressure plate and clutch like 2 months ago
Old Nov 8, 2004 | 06:55 PM
quietzone's Avatar
any1?
Old Nov 8, 2004 | 06:59 PM
madhatch's Avatar
mine did the same Stock jdm b18c it turned out the pressure plate gave out, Could be the throw out,
Try to put it in gear then start it with the clutch in,
see what you get fromm there.
Old Nov 8, 2004 | 07:02 PM
quietzone's Avatar
Default Re: b16 tranny (madhatch)
no luck
Old Nov 8, 2004 | 07:05 PM
skunk2eg's Avatar
so the car wont go into gear weather the car is on or off?
Old Nov 8, 2004 | 07:10 PM
quietzone's Avatar
Default Re: b16 tranny (skunk2eg)
the car won't move at all?
Old Nov 8, 2004 | 07:56 PM
classof04's Avatar
maybe the flywheel?
Old Nov 8, 2004 | 08:04 PM
Built to Spill's Avatar
el diablo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by classof04 &raquo;</TD></TR><TR><TD CLASS="quote">maybe the flywheel?</TD></TR></TABLE>
Doubt it.
Sounds like a clutch problem bro. Who put it in?
Old Nov 9, 2004 | 08:27 AM
madhatch's Avatar
okay so car not running still wont go in gear then start?
Bent fork or bad clutch completly (pressure plate)
Old Nov 16, 2004 | 06:54 PM
Circuit Star-29's Avatar
Default Re: (madhatch)
Bump this because I have a friend with the same problem....Except, when you put in to gear when the car is off and then start it up, the clutch grabs a little but will let you drive.
Spody02
Apr 21, 2008 09:36 PM
s0n!c's Ls inTeG
Apr 29, 2007 07:05 PM
meltman1234
Sep 23, 2005 11:45 AM
LSeeper
May 12, 2004 08:15 PM
