Header out or muffler for track?
What setup can yield greater gains? Running header out or having an exhaust such as a Fireball or N1 with testpipe and 2.5 piping all around? I will be using the R strictly for track so sound isn't an issue at all. What do you guys think?
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
If sound is no issue then you don't run in sanctioned events or on tracks that impose sound limits I assume? I'm doing a side exit, no resonator, no muffler setup. Will hopefully get the piping, bends, etc this weekend so sat or sun I'll weld the system together and then dyno it on the 12th.
Correct!, Are you trying to achieve some type of gain by putting some length of piping after the header? I mean is there any difference between what your doing and what im thinking of doing aside from looks.
Adam: That's what I'll be doing for my ITA integra as well. Cept my welds probably wont be THAT nice
Yeah ... it has some real clean welds. John at Hytech made it for me
I was under the impression that an open header setup is inferior to adding at least a couple feet of piping after the collector. You need something to help maintain the velocity of exhaust gasses coming from the exhaust manifold. Otherwise, you could just run an open head! Usually, a few feet of pipe after the collector is all you need. Also, most sanctioning bodies require that the exhaust gasses are expelled behind the driver, if I'm not mistaken.
Nice setups, guys!
Nice setups, guys!
I agree 231,
I too have read for a long time now that running just the open header without at least some piping that is tuned to maintain exhaust velocity and reduce unwanted backpressure will actually detract from the cars performance, especially with a 1.8 liter engine that has far less exhaust velocity than say a C5 Corvette.
If sound, and law really was NOT the issue then, would we all run around with open headers?
H'mmm. also it was posted that the side exit piping was going to be dynoed, so is that to tune the exhaust pipe and do away with these negative issues?
How much HP are gained by running an open header?
Very Interesting,
A.
Very Interesting,
A.
But isnt it true that at higher rpm's, the shorter the length of the piping the more power you would be getting? The exhaust gas would not need to travel through a lnegth of piping, rather it would be able to exit the engine and reach the atmosphere much quicker.
Nice setups, guys!
Nice setups, guys!
If you went open head, your car would run like complete ***.
The goal is not to get the exhaust gasses into the atmosphere ASAP. The goal is to get all of the burnt gasses out of the cylinder at each exhaust stroke. I still believe that most exhaust manifolds would benefit from having at least a couple of feet after the collector to maintain gas velocity, unless the header was built to run open (see the DC race header as an example...it's supposed to run open, and it's a couple feet longer after the collector, not that DC is any kind of reference point, LOL!).
I can't be completely sure as to how much different your engine would respond then mine....but what worked best for me was removing Adams extension section and bolting the muffler right to the end of the header. best performance for me was........
1. open header(with a specific pimary and secondary length
2. same as above with muffler on end of header
3. same as 1 with extension with muffler on the end exactly like adams
4. full system.
going from number 3 to 2 i gained roughly 2/10's in the quarter mile
going from number 2 to 1 i gained roughly 1/10+ in the quarter mile
4. full system.
4. full system.
4. full system.
i did actually...and thats how i began to see that the quick exit worked best. i just didn't mention that testing. Some of my events i have to use a muffled vehicle. so what i did was......go with the same system adam uses now. then i removed the muffler when there are no sound ordinances. I then tried it shorter and pulled out the extension and ran open header only. on muffled days i just put the muffler on the end of the header. i came out with the results from above after trying different cam gear settings.
quickda6
13
Jul 4, 2004 04:33 PM
