A 00 B18c1 in a 97 hatch, what ECU?
Old Nov 6, 2004 | 05:59 PM
jimmhatch's Avatar
Default A 00 B18c1 in a 97 hatch, what ECU?
What would be the best ecu to use? or what ecu can I use? Also, I'm located in California.
Old Nov 6, 2004 | 06:00 PM
ek9800's Avatar
Default Re: A 00 B18c1 in a 97 hatch, what ECU? (jimmhatch)
you can use the ECU that came with it..the p72 i believe
Old Nov 6, 2004 | 06:06 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: A 00 B18c1 in a 97 hatch, what ECU? (ek9800)
yup the p72 is the way to go.
Old Nov 6, 2004 | 06:07 PM
Calvinator's Avatar
yep obd2 p72.
Old Nov 7, 2004 | 07:57 AM
jimmhatch's Avatar
Default Re: (xtremeazian)
a 96-98 civic ex harness will be used, which p72 can i use? the obd2a or obd2b? or should i just get a obd2->obd1 jumper and get a chipped p28?
Old Nov 7, 2004 | 08:34 AM
Mr. Badwrench
Default Re: (jimmhatch)
use your ex harness with a obd2a p72. a chipped p28 will be ok but why spend the loot on a jumper harness?
Old Nov 7, 2004 | 09:16 AM
null.'s Avatar
Default Re: (boostedcivicsir)
obd2a p72 believe thats from a 96-99 integra gsr
Old Nov 7, 2004 | 10:03 AM
jimmhatch's Avatar
Default Re: (EJ7COUPE)
if i use the 96-98 ex harness with the obd2a p72 ecu, would i throw any codes? would the engine check light go on?
Old Nov 7, 2004 | 10:22 AM
RS Design's Avatar
you hav eto use 96-98 ... anything higher has a immobilizer
Old Nov 7, 2004 | 12:00 PM
jimmhatch's Avatar
Default Re: (909area)
ok thanks everyone!
ek fan
May 27, 2008 09:25 PM
Z you later
Oct 22, 2007 09:03 AM
bmxmarine
Mar 7, 2005 08:48 AM
Fallen
Aug 19, 2003 11:02 PM
97 CIVIC EX
Aug 18, 2002 06:48 AM
