water temp guage
Old Nov 6, 2004 | 04:53 PM
hcivic99's Avatar
Default water temp guage
hey i am wondering were i would need to tap the hole for a water pressure guage and if any one has a pic of it it would be greatly appresheated
Old Nov 6, 2004 | 05:21 PM
hcivic99's Avatar
Default Re: water temp guage (hcivic99)
bump
Old Nov 6, 2004 | 05:30 PM
boostedcivicsir's Avatar
Mr. Badwrench
ac autotechnic has an in line hose adapter that works the best. i have never installed a temp gauge but if you didnt want to go that way, there is a single pin sensor in the side of the head that works the stock gauge. you can put it there.
http://66.235.211.201/acautote...7.htm
Old Nov 6, 2004 | 05:38 PM
specv5150's Avatar
Default Re: water temp guage (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">ac autotechnic has an in line hose adapter that works the best. i have never installed a temp gauge but if you didnt want to go that way, there is a single pin sensor in the side of the head that works the stock gauge. you can put it there.
http://66.235.211.201/acautote...7.htm</TD></TR></TABLE>
GReddy makes those too. You could proably make a variant of that with piping from autozone for cheaper
Old Nov 7, 2004 | 09:06 AM
hcivic99's Avatar
ANy one have detaled instrctions or pictures of how to do this?
Old Nov 9, 2004 | 06:22 PM
hcivic99's Avatar
bump
for instructions
Old Nov 10, 2004 | 03:35 AM
specv5150's Avatar
dude if you buy one of those pre-made ones, all you do is cut the upper rad hose and then put that thing in between it. If you make your own, you do the same thing, but you have to get the piping tapped for the size your sensor is. It isnt too hard. Just buy oin of these and go from there.
Old Nov 10, 2004 | 01:09 PM
hcivic99's Avatar
Default Re: (specv5150)
well how would i make one of my own?
Old Nov 10, 2004 | 01:35 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (hcivic99)
In a D-series head just under the distributor there are a pair of hex-screws that sit flush with the aluminum. One of them (top, I think) is for coolant, bottom is for oil. Most oil pressure and coolant temperature sensors will thread into these holes without any trouble. That's what I tapped my oil pressure gauge on my Autometer, only after discovering that the top one was coolant and not oil .
Old Nov 10, 2004 | 02:20 PM
specv5150's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">In a D-series head just under the distributor there are a pair of hex-screws that sit flush with the aluminum. One of them (top, I think) is for coolant, bottom is for oil. Most oil pressure and coolant temperature sensors will thread into these holes without any trouble. That's what I tapped my oil pressure gauge on my Autometer, only after discovering that the top one was coolant and not oil .</TD></TR></TABLE>
Good info I have a gauge I tried to sell on the cheap to no avail so I may just install it for ***** and giggles now.
Old Nov 10, 2004 | 05:31 PM
hcivic99's Avatar
bump
Old Nov 10, 2004 | 06:48 PM
xZeler8's Avatar
upper or lower radiator hose?
Old Nov 10, 2004 | 06:50 PM
civictildeath's Avatar
Default Re: water temp guage (xZeler8)
make sure to put a "t" connector so your stock gauge will work and not throw codes
Old Nov 12, 2004 | 12:56 PM
hcivic99's Avatar
bump
Old Nov 13, 2004 | 05:12 AM
hcivic99's Avatar
so i am looking at my engine and i see a port were there apears to be a stock sencer in it is closes to the fan and i am wondering what isi that and can i put my water temp guage in there?
Old Nov 13, 2004 | 06:32 PM
hcivic99's Avatar
bump
Old Nov 15, 2004 | 05:37 PM
hcivic99's Avatar
bump
Old Nov 18, 2004 | 04:43 PM
hcivic99's Avatar
bump please help
Old Nov 18, 2004 | 04:46 PM
JDMlyfestyle's Avatar
if u have a manual fan switch you can fit a sensor into the spot where the fan switch is.
Old Nov 18, 2004 | 04:49 PM
hcivic99's Avatar
Default Re: (JDMlyfestyle)
were is that and will it efet any thing?
JBLAZE622
Mar 22, 2009 06:26 AM
powerdbygarrett
Oct 15, 2007 04:55 PM
Casey
Mar 18, 2004 10:22 AM
TypeR15
Feb 24, 2004 12:29 PM
ten_30
Oct 2, 2002 11:08 AM
