Just picked up a 98 GS Few Basic Questions
Old Nov 6, 2004 | 04:41 PM
mrtrex's Avatar
Default Just picked up a 98 GS Few Basic Questions
1. Will a gsr apexi exhaust fit on the GS? Or does the GS have a slightly different exhaust set up.
2. Same question as above involving the header.
Old Nov 6, 2004 | 05:06 PM
dt4life's Avatar
Default Re: Just picked up a 98 GS Few Basic Questions (mrtrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtrex &raquo;</TD></TR><TR><TD CLASS="quote">1. Will a gsr apexi exhaust fit on the GS? Or does the GS have a slightly different exhaust set up.
Welcome to the integra world. 94-99 GSRs have a different exhaust and header then the rest of the teggy line up (RS, GS, LS, Type R). I believe the GSR has a shorter header and longer exhaust while the others have a longer header and shorter exhaust
Old Nov 12, 2004 | 05:18 AM
mrtrex's Avatar
Default Re: Just picked up a 98 GS Few Basic Questions (wannaTypeR)
So the 98 ls has the same header and exhaust set up as the type r??
Old Nov 12, 2004 | 05:48 AM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtrex &raquo;</TD></TR><TR><TD CLASS="quote">So the 98 ls has the same header and exhaust set up as the type r?? </TD></TR></TABLE>
no, the the type r has larger diameter header and exhaust and is designed differently to flow better. however, the dimensions are the same, so if you see a header that will fit a 97-01 type r, it should fit your gs. 00-01 gsr's also have the same dimensions for the exhaust so they will work with your setup as well.
just remember this, in terms of exhaust fitment:
97-01 itr = 94-01 ls/gs/rs = 00-01 gsr
Old Nov 12, 2004 | 07:51 AM
mrtrex's Avatar
Default Re: Just picked up a 98 GS Few Basic Questions (dFreezy)
cool thanks, That opens up my options
ahmongboi
Feb 13, 2011 08:28 AM
EFboosted
Nov 12, 2010 11:15 AM
19integra94
Apr 16, 2009 08:24 AM
little B
May 3, 2007 10:25 AM
acatak
Aug 29, 2002 11:13 AM
