Engine not starting...
Old Nov 6, 2004 | 04:15 PM
ExcessiveCRX's Avatar
Default Engine not starting...
Hey so I have the new SOHC VTEC ZC in the engine bay all hooked up to the best of my knowledge and when I try to start her up it wants to start but it just wont. I'm getting gas, spark, and air but she wont start up. Please help me and toss out as many suggestions as possible so I can get this baby going and rip around in it.
btw, my vtec solenoid is currently not hooked up to anything as I am still figuring out the wiring. Do I need to run a ground from that wire for the car to start?
Thank You!
Old Nov 7, 2004 | 12:11 AM
Default Re: Engine not starting... (ExcessiveCRX)
PLEASE HELP ME PLEASE
Old Nov 7, 2004 | 12:59 AM
Burlyirishdude's Avatar
Is she cranking?
Try checking:
Grounds
battery(low maybe)
Hate to be a Cop-out BUT - "is your fuel relay activating when you turn on the car?"
As for wiring don't forget to ground that wire...
good luck dude
Old Nov 7, 2004 | 01:07 AM
Default Re: Engine not starting... (Burlyirishdude)
She wants to start soooo bad she cranks at first then dies out right away and if I try to start her after that I just get regular noises from the starter and no cranking then eventually full horrible clicking sounds (I'm guessing because the battery is old and I have been trying to start the car 10000 times now).
If anyone can answer this it may help:
Does the vtec solenoid NEED to be plugged into anything in order for the car to start?
Thanks!
Old Nov 7, 2004 | 01:08 AM
and yes fuel pump is pressurizing is that what you mean?
Old Nov 7, 2004 | 05:06 AM
ekoms31's Avatar
do you have compression
Old Nov 7, 2004 | 05:16 AM
tuoniz's Avatar
Default Re: Engine not starting... (ekoms31)
check compression, then plug spark, battery, cables, fuel system not in that order
Old Nov 7, 2004 | 09:43 AM
Default Re: Engine not starting... (tuoniz)
I have got all of those things!
Old Nov 7, 2004 | 11:22 AM
drussell4801's Avatar
check them again.
Old Nov 7, 2004 | 01:02 PM
Default Re: Engine not starting... (drussell4801)
She even revs up to 1000 rpm for 2 seconds or so then just dies out.
Old Nov 7, 2004 | 01:57 PM
singlecamcrx's Avatar
im having problems with my car also. my car starts up then it dies like after a few seconds. sometimes it starts and just dies right when my CEL light goes nuts and flashes hella times and while the CEL is flashing a relay under the dash next to the fuses is clicking. its a little black cube shaped that says Relay Assembly on it. and whenever i give it gas the car dies.
Old Nov 7, 2004 | 10:56 PM
Default Re: Engine not starting... (NitrousCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousCrx &raquo;</TD></TR><TR><TD CLASS="quote">im having problems with my car also. my car starts up then it dies like after a few seconds. sometimes it starts and just dies right when my CEL light goes nuts and flashes hella times and while the CEL is flashing a relay under the dash next to the fuses is clicking. its a little black cube shaped that says Relay Assembly on it. and whenever i give it gas the car dies.</TD></TR></TABLE>
yours is probably main relay.. dunno if his could be the same..
that would be weird..
Kid-jdm-teggy
Aug 27, 2013 11:49 AM
Jstnj03
Apr 26, 2008 11:07 AM
justseeingifitistaken
Nov 11, 2006 02:30 PM
ocks
May 14, 2006 10:38 PM
jasongallagher
May 27, 2002 01:36 PM
