Running Lean at WOT.
Old Nov 6, 2004 | 04:11 PM
bo0sted's Avatar
Default Running Lean at WOT.
I have been driving my rebuilt engine for over 5k+ miles now and it has been fine untill recently. On WOT no matter what gear or RPM, I run lean. I can take a gear to redline at 25% throttle and I run fine (little rich actually). So the problem is only happening when I go more then 75% throttle.
What could be causing me to run lean on WOT? I already have a fuel filter being shipped since I have never changed it. The car has about 65,000miles. Let me know what else to look for.
Old Nov 6, 2004 | 04:51 PM
UnKnownUser's Avatar
Default Re: Running Lean at WOT. (MwGSR)
Get it tuned now!
Old Nov 6, 2004 | 04:57 PM
aznballer's Avatar
yeah i agree get it tuned or, if u have sum program that can add fuel raise ur fuel curve
Old Nov 6, 2004 | 04:58 PM
jdmotorsports's Avatar
Default Re: Running Lean at WOT. (LSVTEC_DC4)
could be a bad tps sensor. i would check and see if yours is binding up somewhere.
Old Nov 6, 2004 | 05:17 PM
B2FiNiTY's Avatar
Is it stock? I wouldn't push the car at all if it is lean.
Old Nov 6, 2004 | 07:04 PM
Default Re: Running Lean at WOT. (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Is it stock? I wouldn't push the car at all if it is lean. </TD></TR></TABLE>
If its lean period, i wouldent push it at all...
Old Nov 6, 2004 | 09:21 PM
bo0sted's Avatar
Tuning has nothing to do with it. Like i said it was perfect untill the last week. Obviously something has went out or got clogged in order for it to run lean. Going to get it tuned and dumping a bunch of extra fuel in it isnt really going to fix the problem. Any other suggestions?
Old Nov 6, 2004 | 09:23 PM
bo0sted's Avatar
Where is the TPS located? I'll look into that.
Old Nov 6, 2004 | 09:28 PM
on the trottle body. directly opposite the throtle cable pulley. see if its damaged or came unhooked.
Old Nov 6, 2004 | 09:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MwGSR &raquo;</TD></TR><TR><TD CLASS="quote">Where is the TPS located? I'll look into that.</TD></TR></TABLE>
You dont know where that is, good luck bro
Old Nov 6, 2004 | 09:35 PM
bo0sted's Avatar
Default Re: Running Lean at WOT. (jdmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">on the trottle body. directly opposite the throtle cable pulley. see if its damaged or came unhooked.</TD></TR></TABLE>
Oh ok yah its good.
Old Nov 6, 2004 | 09:36 PM
bo0sted's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC_DC4 &raquo;</TD></TR><TR><TD CLASS="quote">
You dont know where that is, good luck bro</TD></TR></TABLE>
Take your stupid comments elsewhere. I'm trying to get input and i dont need to hear your stupid ****.
Old Nov 7, 2004 | 09:15 AM
bo0sted's Avatar
Any one else have any ideas?
DawgC2
Mar 10, 2012 12:11 PM
maxamusprime
Jan 21, 2007 02:30 PM
honda9369
Sep 22, 2004 03:45 PM
speedaccordinly24
Apr 25, 2003 04:15 AM
raene
Jul 17, 2001 12:32 PM
