Car Die when im at a stop light PLEASE HELP ME!!!
Old Nov 6, 2004 | 12:54 PM
JDMFreak's Avatar
Default Car Die when im at a stop light PLEASE HELP ME!!!
ok guys, i have a b20b in my 00 civic, im currently using a H22 TB, and everyone so often when i park at a stop light, my idle will drop down to 500 and the car die on me, my currently idle is set at 900-1000, it drive normally no CEL or anything, the wierd thing is i used have a CRV TB and it work fine, but im having MAP sensor issue with that TB so i decide to go with H22 instead....help me out guys!!!
Old Nov 6, 2004 | 04:57 PM
JDMFreak's Avatar
Default Re: Car Die when im at a stop light PLEASE HELP ME!!! (JDMFreak)
wow, no one read it, dinner bump
Old Nov 6, 2004 | 05:02 PM
hayabusa160's Avatar
my car used to do that turned out my timing was really retarded. and running really rich
Old Nov 6, 2004 | 05:48 PM
JDMFreak's Avatar
Default Re: Car Die when im at a stop light PLEASE HELP ME!!! (hayabusa160)
now that you mention it that way, i did advance the timing with my old ECU, should i do the timing? and put it back to normal?
Old Nov 6, 2004 | 05:53 PM
check ur timing set to factory specs
Old Nov 11, 2004 | 05:29 PM
andyhurz20's Avatar
Definatly check your timing. But just in case it's not that, one of my friend had to change out a little valve spring that went bad that controlled the Idle.
Nick Comstock
Sep 5, 2022 02:14 PM
eg6sir88
Jul 22, 2010 08:01 PM
Tatakai
Apr 25, 2007 10:41 PM
275Performance
Jan 25, 2007 09:13 AM
Civic89
Aug 8, 2002 01:48 PM
