Car Die when im at a stop light PLEASE HELP ME!!!
ok guys, i have a b20b in my 00 civic, im currently using a H22 TB, and everyone so often when i park at a stop light, my idle will drop down to 500 and the car die on me, my currently idle is set at 900-1000, it drive normally no CEL or anything, the wierd thing is i used have a CRV TB and it work fine, but im having MAP sensor issue with that TB so i decide to go with H22 instead....help me out guys!!!
Re: Car Die when im at a stop light PLEASE HELP ME!!! (hayabusa160)
now that you mention it that way, i did advance the timing with my old ECU, should i do the timing? and put it back to normal?
Definatly check your timing. But just in case it's not that, one of my friend had to change out a little valve spring that went bad that controlled the Idle.
Nick Comstock
09-05-2022 02:14 PM
275Performance
01-25-2007 09:13 AM
