electronic exhaust cutout???
Old Nov 6, 2004 | 11:55 AM
civic gtr's Avatar
Default electronic exhaust cutout???
i tried searching but its down right now.
is there such thing as a cutout that is electronic that can be opened from inside the car? im planning on running 2.5" piping connected to stock cx exhaust but with a cutout in between connected to a resonator so it dont sound like ****.
where can i find a cutout that can be opened/closed from inside the car?
Old Nov 6, 2004 | 11:57 AM
Eskay@JDMCircle.com's Avatar
yes, search google. mccord power plate, quicktime qtec cutout, ect..
Old Nov 6, 2004 | 12:08 PM
civic gtr's Avatar
ive seen em go around $175
do they have anything cheaper? anybody know?
Old Nov 6, 2004 | 12:11 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (civic gtr)
You could always get a mechanical one and just uncork it at the track if you're truly concerned about a $200 pricetag.
Old Nov 6, 2004 | 12:15 PM
civic gtr's Avatar
Default Re: (Archidictus)
thats the thing. my car looks like a pos with stock everything. i want an electronic one just in case some stunna revs at my pos so i can flip the switch and run him. it does happen sometimes just cuz its a hatch.
Old Nov 6, 2004 | 12:27 PM
Kamin's Avatar
a cutout may hurt your performance. backpressure is necessary for proper scavenging.
too much volume = not enough flow. think if you have a straw 6 inches around, you couldnt create enough vacuum to move anything through it. likewise the exhaust needs that pressure to effiectvley move the burnt **** out of the cylinder.
Old Nov 6, 2004 | 12:31 PM
civic gtr's Avatar
Default Re: (Kamin)
but i thought running open headers increase performae because it breathes alot easier? people do it in the track so i guess it helps?
IntegraLova's Avatar
if your motor is stock your not going to get a surge of horsepower from opening the cutout. The cutout will kill your low end power if you open it then.The cut out should be opened mid-high/high end of your rpm range bc thats really the only time you would benifit from it.And with a stock motor i could think of many things you could do to get some more hp other than an e-cutout.
Old Nov 6, 2004 | 12:33 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic gtr &raquo;</TD></TR><TR><TD CLASS="quote">but i thought running open headers increase performae because it breathes alot easier? people do it in the track so i guess it helps?</TD></TR></TABLE>
people do it because they think it helps, it is a HUGE misconception by many many people. a free flowing exhaust will help, but some backpressure is indefinatley necessary for the engine to make peak power.
example: small block 350 in a t-bucket, open header. we gained about 8 WHP with a header EXTENSION making the exhaust longer.
unless you understand the intricate workings of how the exhaust works (wich it really is, its not just a pipe) its very hard to understand, just know there is more to the exhaust than the bigger the hole the better the engine breathes.
U.S. Soldier
Mar 18, 2009 06:30 PM
Boostin_GSR
Dec 9, 2007 06:40 PM
TRAG
Honda Civic (2006 - 2015)
Sep 6, 2006 07:56 AM
JdmSlammedEG6
Oct 27, 2004 10:45 PM
SpeedDemonAaron
Jul 24, 2004 06:36 PM
