wiring diagram for a 97 civic
Old Nov 6, 2004 | 09:35 AM
JDMallTHEway's Avatar
Default wiring diagram for a 97 civic
anyone have one, I need to figure out where to wire my air fuel gauge into
the ecu.
Old Nov 6, 2004 | 09:36 AM
Luserkid's Avatar
Default Re: wiring diagram for a 97 civic (JDMallTHEway)
white wire of the o2 sensor.
Old Nov 6, 2004 | 09:37 AM
Ricey McRicerton's Avatar
Default Re: wiring diagram for a 97 civic (Luserkid)
If it's not a wideband, you're just getting an expensive light show...
Old Nov 6, 2004 | 09:40 AM
Br1anPham's Avatar
Default Re: wiring diagram for a 97 civic (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">If it's not a wideband, you're just getting an expensive light show...</TD></TR></TABLE>
What he said.
I can confirm this.
Old Nov 6, 2004 | 09:59 AM
Default Re: wiring diagram for a 97 civic (Br1anPham)
don't know much about this, waht do you mean.
Old Nov 6, 2004 | 10:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMallTHEway &raquo;</TD></TR><TR><TD CLASS="quote">don't know much about this, waht do you mean.</TD></TR></TABLE>
Your stock 02 sensor only read a small portion of the A/F range. The signal that it puts out is between 0-1V if I remember correctly. With my Techedge 1.0, the signal goes between 0-5V. I'll have 5 times as much reading out of a wideband than you will out of a stock 02 sensor. You may be able to fine tune it if you get it within that small reading area, but if you go rich or lean off of that, you have no idea how rich or how lean you are.
Old Nov 6, 2004 | 10:25 AM
ok, now I understand, how much should is reasonable to pay for a wideband 02 sensor?
Old Nov 6, 2004 | 10:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMallTHEway &raquo;</TD></TR><TR><TD CLASS="quote">ok, now I understand, how much should is reasonable to pay for a wideband 02 sensor?</TD></TR></TABLE>
You can do a custom built Techedge pretty cheap now. If you buy the prebuilt I think they're somewhere around 300-400 dollars.
Old Nov 6, 2004 | 11:43 AM
Frozen E's Avatar
H-T White Ops
Look in the FI classified forum. There's a sale on the PLX M-300/500 going on in there. I picked mine up from there. I think they're starting at around $300 and some change.
haroldthefly91crx
Aug 24, 2007 07:25 AM
B20VTI
Jun 27, 2006 09:53 AM
J Rob
Dec 18, 2005 03:24 PM
IVI
Mar 27, 2004 04:47 AM
Honda Type R
Aug 18, 2003 09:47 AM
