Knock Sensor & timing retard
Old Nov 6, 2004 | 09:11 AM
sleeperb16a's Avatar
Default Knock Sensor & timing retard
1. By how many degrees does the knock sensor pull back the ignition timing on an OBD0 b16a?
2. And once the knock sensor detects detonation and retards the timing, how long does it hold it back? As long as the throttle is depressed?
3. While launching in 1st, if there is slight detonation and the KS pulls back the timing, will it keep the timing retarded throughout the quarter mile pass?
Searched for the answers to these questions but could not come up with any.
TIA
Old Nov 6, 2004 | 10:52 AM
PrettyLude's Avatar
3 degrees
it will hold timing like that until u fix the problem
yes
Old Nov 6, 2004 | 10:32 PM
Default Re: (PrettyLude)
PrettyLude,
Thanks for the replies. Just one more question, do i have to reset the ecu after adjusting the timing manually from the distributor?
Old Nov 7, 2004 | 08:09 AM
drdisco69's Avatar
Default Re: (sleeperb16a)
From my understanding, this is my answers to your questions:
1. The computer will pull out 3 degrees of timing every time it detects 3 knocks in 2 seconds.
2. It will continue this until it doesn't detect those 3 knocks in 2 seconds. It will then try to advance the timing by 3 degrees, still following it's 3 in 2 rule.
3. It should have all the timing back in by the end of the quarter mile, unless you're getting a lot of detonation, or running 6's.
You don't have to reset the ecu after adjusting timing.
Old Nov 7, 2004 | 11:42 AM
Default Re: (drdisco69)
Thanks drdisco69!
These answers were not available anywhere......honda-tech rocks!
Old Nov 18, 2004 | 06:06 AM
integra95gsr's Avatar
so on the V-AFC what is the setting you can adjust to the KS?
Old Nov 18, 2004 | 01:21 PM
PrettyLude's Avatar
i don't think you can adjust it, just monitor it
Old Nov 18, 2004 | 08:08 PM
ehh nice! thank you! (sorry im new to this stuff)
Old Nov 19, 2004 | 12:34 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">i don't think you can adjust it, just monitor it</TD></TR></TABLE>
Actually you cannot adjust or monitor it with a VAFC.
Old Nov 19, 2004 | 07:32 AM
Used2beAb16's Avatar
Default Re: (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Actually you cannot adjust or monitor it with a VAFC.</TD></TR></TABLE>
AnAccordIsForever
May 7, 2009 09:08 AM
be18see1
Apr 9, 2008 05:32 AM
AnAccordIsForever
Nov 13, 2007 08:31 AM
toooslow
Apr 24, 2003 04:24 PM
