B16A1 -> B16B
Old Nov 6, 2004 | 06:30 AM
EE9_B16B's Avatar
Default B16A1 -> B16B
Hi guys. I have a Civic Vtec 1991 (ee9). https://honda-tech.com/zero...ge=24
My motor is quite old (240.000 km). The motor is in GREAT condition but i want to upgrade it in a few months. I have bought some Type-R products.
1)B18C Intake Manifold
2)B16B Pistons
3)B16B Camshafts
4)B16B Dual valve springs + retainers
In the next few days i will buy:
1)DC 4-1 Header
2)HKS Filter (80/200)
3)Custom Exhaust system (60mm diametre????)
4)Custom Made ECU
5)Oil Catch Tank
6)HODNATA intake manifold gasket
I have some questions though:
1)Do i need cam gears to tune the cams? (aftermarket or Type-R)
2)If you look @ the pic showing the valve springs, there are 3 types of SMALL springs! 8 of them are orange. 6 of them are red, and 2 of them are yellow!! Why ?? Which cylinder needs diffrent rates and why??
pics:
thanks!
Old Nov 6, 2004 | 09:00 AM
HamiltonRex's Avatar
Default Re: B16A1 -> B16B (EE9_B16B)
whooaaa this is not 56K friendly, my T3 took a sec.
Anyways.
The b16b is a destroked version of the b18c5. So the pistons will work on your stock b16 rods. I dont think the rods from the b16b are the same lenght.
The cams and valvesprings will work. Im not too sure about the colors of the valvesprings or what goes where, sorry.
Cam gears could help a bit if you tune them on a dyno. I would just use you stock B16 cam gears. Same as ITR.
Just chip your ECU, much better plan (maybe thats what you ment by custom ecu)
I like my Hondata IM gasket, Keeps the heat down to some degree.
Good luck
Old Nov 6, 2004 | 10:58 AM
JapJunkie's Avatar
Default Re: B16A1 -> B16B (HamiltonRex)
Thats a sexy *** ride u got there U got any interior shots???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE9_B16B &raquo;</TD></TR><TR><TD CLASS="quote"> 1.6L ~150hp. thanks.
Old Nov 6, 2004 | 11:23 AM
EE9_B16B's Avatar
Default Re: B16A1 -> B16B (JapJunkie)
sorry Japjunkie i cant answer your Instant message cause Im a trial user..
Yes the B16 is the stock motor for our civic's and crx's.
Civic/Crx Vtec 1989-1991 --&gt; B16A1 (150hp)
Civic/Del Sol Vti 1992-1996 --&gt; B16A2 (160hp)
Civic Vti 1996-2000 --&gt; B16A2 (160hp)
Civic Type-R 1996-2000 --&gt; B16B (185hp)
Civic Type-R 2000-2004 --&gt; K20 (200hp)
thanks guys..!
Old Nov 6, 2004 | 11:27 AM
EE9_B16B's Avatar
sorry i forgot to mention that i will sell these connecting rods because i cant use them! (like hamiltonrex said). If i install those pistons in my B16A block the compression goes up to 11.2 : 1 which is pretty high, and this is good, cause i want to avoid using a thinner gasket.
stmizner's Avatar
i'm interested in the rods if you don't use them.
Old Nov 6, 2004 | 11:59 AM
EE9_B16B's Avatar
Default Re: B16A1 -> B16B (stmizner)
If you are sure you can use them, i will contact the shop i bought them from and ask them (cause i will return them.) http://www.xm-parts.com They have very good prices in all products.
Old Nov 6, 2004 | 12:07 PM
kim_2_da_chee's Avatar
I want those exact parts! (within 2 years of saving hopefully )
I also want that 1.6i-VT decal
sk8shorty012
Feb 21, 2010 10:44 PM
ex96vtec
Feb 23, 2009 07:28 AM
Jintegragsr97
Feb 21, 2008 08:44 PM
ken-shin
Sep 5, 2004 07:59 PM
RKRKRK
Feb 11, 2004 02:53 PM
