JDM b16sir1 swapped 90 si hatch cam help
Ok I just recieved a jdm sir1 engine swap from auto import salvage and I am preparing to modify the head before imstallation.
I am porting and polishing the head and I plan on upgrading cam/cams and or valvetrain if possible.
I have heard that ctr cams and itr cams are pretty decently priced and I have heard from some people that only the intake needs to be changed.
I have the factory OBDO ecu & rev limiter so any insight will be appreciated.
I am trying to find the best bang for the buck ya know
The car is going to be a daily driver and possible drifting and auto crossing. No drag racer.
Thanks again H-T.
I tried to search but the search engine is not available at this time. I will try again later.
Thanks again H-T.
IMO get aftermarket like toda or crower.. the CTR and ITR only give you a small percentage of increase cuz of the lift and duration(compared to aftermarket onces for the B16 ones)... try getting the aftermarket w/ more aggressive cam profile...
yea i guess if the price is going to be an issue then go ahead compare which of the two has better cam profile and go for that one...
i know how much aftermarket cam could ran ya.. good luck
