Which Tires look good RSZ R...
Old Nov 5, 2004 | 02:58 PM
jdmitr02's Avatar
Default Which Tires look good RSZ R...
Im thinking about two kind of tires.. There are Yokohoma AVS ES 100 and Falken Ziex.. Im looking for 195-50-15.. Do the tire series number look funny on Work RSZ R because the rubber look small.. Please let me know.. Thanks
Oh by the way, I used to have Falken Azenis tires 205-50-15 on Work RSZ R.. It rub crazy and major camber wear..
Modified by jdmitr02 at 4:15 PM 11/5/2004
Old Nov 5, 2004 | 03:02 PM
Opie's Avatar
SumAtuma tieas and dey gotta be run flats y0!
Old Nov 5, 2004 | 03:11 PM
ITR184's Avatar
Default Re: Which Tires look good RSZ R... (jdmitr02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmitr02 &raquo;</TD></TR><TR><TD CLASS="quote">Im thinking about two kind of tires.. There are Yokohoma AVS ES 100 and Falken Ziex.. Im looking for 195-50-15.. Do the tire series number look funny on Work RSZ R.. Please let me know.. Thanks. </TD></TR></TABLE>
Who cares what they look like, go for the grip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmitr02 &raquo;</TD></TR><TR><TD CLASS="quote">Oh by the way, I used to have Falken Azenis tires 205-50-15 on Work RSZ R.. It rub crazy and major camber wear.. </TD></TR></TABLE>
Get a camber correction kit and raise it up some. I think you will have problems out of any tire you put on it with that set up.
Modified by Cod Sac at 12:49 AM 11/6/2004
Old Nov 5, 2004 | 03:37 PM
KOALA YUMMIES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmitr02 &raquo;</TD></TR><TR><TD CLASS="quote">It rub crazy and major camber wear..
Thats a suspension setup problem, camber wear is the sign right there. Toe is probably off.
Tire choice should be done based on what you want out of it, and the kind of driving and weather you encounter. But:
Here's what ES100s look like on JCruz's car (pic by RoaringTurtle)
Old Nov 5, 2004 | 03:46 PM
ITR184's Avatar
Default Re: Which Tires look good RSZ R... (KOALA YUMMIES)
What kind of lug nuts are these? Look like skunk2.
I'll be happy when my RSZ R's get here. I wont be able to put them on until spring though(sucks). Man I miss Florida.
Old Nov 5, 2004 | 03:53 PM
ITR184's Avatar
Nice picture. It gives me an idea of what these are going to look like on my car, but with a bunch more fender gap.
[IMG][http://www.we-todd-did-racing.com/we...DE%3D.jpg/IMG]
Old Nov 5, 2004 | 03:55 PM
Misfit's Avatar
Default Re: Which Tires look good RSZ R... (Cod Sac)
raise your car up...
where did you get those fog lights????
Old Nov 5, 2004 | 04:10 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmitr02 &raquo;</TD></TR><TR><TD CLASS="quote">Im thinking about two kind of tires.. There are Yokohoma AVS ES 100 and Falken Ziex.. Im looking for 195-50-15..</TD></TR></TABLE>
You can get the ES100 in the stock size, 195/55-15. You're better off with that; among other things, your odometer and speedometer will be accurate, instead of reading higher than actual.
Old Nov 5, 2004 | 04:44 PM
Default Re: Which Tires look good RSZ R... (nsxtasy)
Would you really want to put 195s on a 7" wide wheel though?
Old Nov 5, 2004 | 08:19 PM
mikestypeRR's Avatar
[QUOTE=jdmitr02]
cause your car is slammed on its *** yO
Old Nov 5, 2004 | 08:44 PM
gamby's Avatar
Good to see an R being used for its intended purpose. Also good to see all of Honda's millons of dollars of suspension R&D rendered moot.
Never understood the need for megadollar roadrace wheels that only see street use.
Old Nov 5, 2004 | 09:01 PM
Default Re: Which Tires look good RSZ R... (gamby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gamby &raquo;</TD></TR><TR><TD CLASS="quote">Never understood the need for megadollar roadrace wheels that only see street use. </TD></TR></TABLE>
Personally I dont think its very intelligent to roadrace on a wheel that is discontinued, if you bend break or otherwise damage one you're out an entire set of expensive wheels, you got the trend backwards. Usually people use cheap easy to aquire wheels to do any form of racing or HPDEs.
Old Nov 5, 2004 | 09:04 PM
EKen9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">
Usually people use cheap easy to aquire wheels to do any form of racing or HPDEs.</TD></TR></TABLE>
yeah especially cheap-*** ITR owners
Old Nov 5, 2004 | 09:35 PM
MAD ITR 55's Avatar
Default Re: Which Tires look good RSZ R... (EKen9)
I don't know about you,but I choose a tire by it's performance not by the looks of it.
Old Nov 5, 2004 | 10:09 PM
hadboosttroy's Avatar
Default Re: Which Tires look good RSZ R... (misfit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misfit &raquo;</TD></TR><TR><TD CLASS="quote">raise your car up...
where did you get those fog lights????</TD></TR></TABLE>
looks like oem with some film over them? not positive though.
edit: by the way balzac kicks ***. i saw the misfits a few weeks ago, jerry only, dez cadena and marky ramone. it was insane
Old Nov 6, 2004 | 12:07 AM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cod Sac &raquo;</TD></TR><TR><TD CLASS="quote">Who cares what they look like, go for the grip.</TD></TR></TABLE>
thats what i was jus about to say
Old Nov 6, 2004 | 02:31 AM
T0rqueless
Guest
Posts: n/a
Default Re: Which Tires look good RSZ R... (Slow_Em1)
there really should be a sticky that says
"if you have any wheels on your R that are bigger then 15's, dont bother posting here...track damage is cool, and waxing/washing your R is prohibited"
Old Nov 6, 2004 | 05:50 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">Would you really want to put 195s on a 7" wide wheel though?</TD></TR></TABLE>
Sure. The range of approved rim widths is 5.5-7.0 inches, according to Yokohama's specs.
How do you know how wide his wheels are? Are they 7", Kwan?
Old Nov 6, 2004 | 07:15 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
I wouldn't go 195/50 on a DC just for the reasons that they a) tiny, b) look tiny in the wheel wells, c) have rubber band sidewalls compared to 205/50s, d) 205 azenis kick ***, and e) most of the 195/50s out there don't have a load rating suitable for the DC chassis.
And yeah, maybe if you raised your car, got an alignment, or got a camber correction kit in the front, you wouldn't have camber "problems."
Old Nov 6, 2004 | 09:41 AM
He posted a little while ago about how he got them through JHPUSA.com's deal of 5x114.3 RSZR's for $750 a set for the 15x7s.
Old Nov 6, 2004 | 11:15 AM
Chris93Si's Avatar
Personally I dont think its very intelligent to roadrace on a wheel that is discontinued, if you bend break or otherwise damage one you're out an entire set of expensive wheels, you got the trend backwards. Usually people use cheap easy to aquire wheels to do any form of racing or HPDEs.</TD></TR></TABLE>
&lt; Going to track on his RSZ-Rs, if I damage them it's just an excuse to get TE-37s I figure that's what they're made for right
jdmitr02: Just raise the car up a bit and stick w/ Azenis
Old Nov 6, 2004 | 11:59 AM
Kengs's Avatar
Holy crap that is a great pic
Old Nov 6, 2004 | 12:42 PM
daddy ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">He posted a little while ago about how he got them through JHPUSA.com's deal of 5x114.3 RSZR's for $750 a set for the 15x7s. </TD></TR></TABLE>
that seems like a great price for 4 ............ http://www.randdmotorsports.com/detail.cfm?ID=92
the best price I could find was $850 at the site above
Modified by daddy ITR at 12:05 AM 11/7/2004
Old Nov 6, 2004 | 01:41 PM
ITR184's Avatar
Default Re: Which Tires look good RSZ R... (daddy ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddy ITR &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by daddy ITR at 12:05 AM 11/7/2004</TD></TR></TABLE>
I was lucky enough to get the last set JHP had. That was a damn good price. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">
Can always sell the good ones on hear or maybe find one if somebody jacked one up, and went to something different. Might have to wait a while though.
Old Nov 7, 2004 | 11:12 AM
jeremy.'s Avatar
i bought a set and might sell them....any takers?
