sir cluster wont go under 43kph?
Old Nov 5, 2004 | 01:58 PM
mikecivichb's Avatar
Default sir cluster wont go under 43kph?
I installed a crx sir cluster into my crx and installed the vss. The speedo wont go under 43kph. When I drive it will go up and down but never below 43kph. As soon as I stick the key into the ingnition and turn to acc. It will jump to 43kph. any Ideas? Is there a way to adjust the vss or no? what do you think it is?
Old Nov 5, 2004 | 02:00 PM
eumoria's Avatar
Default Re: sir cluster wont go under 43kph? (mikecivichb)
electrical problem in the cluster
if you did all the wiring yourself you may have open wires touching causing a + voltage to be leaking into the pulse causing the constant 43km/h. Recheck your wiring.
Old Nov 5, 2004 | 02:10 PM
Nic's Avatar
Nic
Default Re: sir cluster wont go under 43kph? (eumoria)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eumoria &raquo;</TD></TR><TR><TD CLASS="quote">electrical problem in the cluster
if you did all the wiring yourself you may have open wires touching causing a + voltage to be leaking into the pulse causing the constant 43km/h. Recheck your wiring.</TD></TR></TABLE>
Old Nov 5, 2004 | 07:22 PM
Default Re: sir cluster wont go under 43kph? (stk crx)
nothing is touching everything has been soldered and shrink wrapped.
Old Nov 6, 2004 | 06:25 AM
ttt
Old Nov 6, 2004 | 07:23 PM
Is there a way to adjust the speedo? I always thought you could but does anyone know how?
Old Nov 7, 2004 | 07:51 AM
ttt
Old Nov 8, 2004 | 10:46 AM
Default Re: sir cluster wont go under 43kph? (EFHondaRue)
thanks alot.
Old Nov 8, 2004 | 10:55 AM
Deetz's Avatar
Crazy Honda Guy
It may cery well be that someone had taken off the speedo needle and not put it back on properly. You could try removing it and reinstalling it so that it rests at zero. just make sure to have the running speed verified afterwards.
Old Nov 8, 2004 | 11:31 AM
HamiltonRex's Avatar
Default Re: (Deetz)
if it isnt a wiring issue. faulty speedo.
Old Nov 8, 2004 | 06:27 PM
Default Re: (Deetz)
the speedo will just snap on and off???? Im not worried about the speedo being off I just want it to look like it should.
Old Nov 9, 2004 | 07:48 PM
Default Re: (mikecivichb)
I just tried pulling off the needles on a old dx cluster I found and I pry the needles off and they wont go back on is there a tool or something that I would have to use.
Old Nov 10, 2004 | 11:27 AM
ttt
french_yogi
Apr 18, 2011 06:24 PM
spettinger
May 11, 2003 08:16 PM
LB CRX
14
Aug 31, 2002 08:34 PM
