ITR vs. GSR shift linkage..MikeK??
Yes...
ITR Shift Linkage = ITR Shifter
Suprdave
Suprdave
same thing dude!
they might have different part numbers, Honda/Acura like to use lots of different part numbers.
not sure what metal the itr linkage is made out of but its alot lighter. (goldish color) Not sure if it improves shifting or not. came with my swap.
Only JDM is a different color. USDM is plain black.
Shifter and shift linkage are two separate things.
The shifter itself is identical, the linkage is different. Larger diameter and
hollow if im not mistaken.
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
The shifter is the same.
The extension rod is the same.
The change rod is about .01 lbs lighter. GSR has a little metal piece at the end, and the ITR does not.
There's not much difference in weight at all.
But for those interested, the ITR linkage is a few bucks cheaper than GSR.
