what is needed for 50,000 tune up?
Old Nov 5, 2004 | 10:42 AM
jeremy.'s Avatar
Default what is needed for 50,000 tune up?
creepin up on 50,000 miles......what parts are needed and what is to be done? thanks
Old Nov 5, 2004 | 10:44 AM
Jon D's Avatar
Default Re: what is needed for 50,000 tune up? (ekay_jeremy)
hmmm..... 50k miles. Your probably just wanna go ahead and sell me j00 cah for the $3500 its worth with such high miles and buy a Neon
On Topic: .....check the FAQ
Old Nov 5, 2004 | 10:51 AM
jeremy.'s Avatar
Default Re: what is needed for 50,000 tune up? (B18C-Rsi)
is it there? my bad sorry
Old Nov 5, 2004 | 10:54 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">creepin up on 50,000 miles......what parts are needed and what is to be done?</TD></TR></TABLE>
Nothing. The mileage intervals for major services to the ITR are 15K miles, 30K, 45K, 60K, etc. There is no "50,000 mile tune-up".
Have you bothered to look at the maintenance schedule in your owner's manual?
Old Nov 5, 2004 | 11:00 AM
jeremy.'s Avatar
Default Re: what is needed for 50,000 tune up? (nsxtasy)
no i don't have a manual.....what is needed for 45,000 then?
Old Nov 5, 2004 | 11:15 AM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">no i don't have a manual.....what is needed for 45,000 then?</TD></TR></TABLE> it requires that you trade for a 99' milano red Si with stealies and a 1st gen. B16
Old Nov 5, 2004 | 11:21 AM
jeremy.'s Avatar
Default Re: what is needed for 50,000 tune up? (Slow_Em1)
done deal
Old Nov 5, 2004 | 11:27 AM
nsxtasy's Avatar
H-T Order of Merit
Buying an owner's manual would be the first thing you should do. You can buy one here. If you plan to work on your car yourself, you can (and should) get a service manual from the same place. The maintenance schedule appears in both manuals.
Old Nov 5, 2004 | 11:33 AM
jeremy.'s Avatar
thanks...mine is in the mail
Old Nov 7, 2004 | 12:21 PM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">done deal</TD></TR></TABLE>aight ill be home all week!
Old Nov 7, 2004 | 12:45 PM
jeremy.'s Avatar
cool trade cars plus bj's everyday for life
Old Nov 7, 2004 | 12:56 PM
PriMaTe's Avatar
you guys are so useful, 10 posts deep and the best advice is "get a manual", and "there's no 50k service". Maybe you wanna tell him what the 45k and 60k says so he has some sort of idea?
Old Nov 7, 2004 | 02:23 PM
nightrider's Avatar
i'm a little passed 50k and i was thinking doing all my fluids and get a new timing belt to be safe.
Old Nov 7, 2004 | 04:15 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: what is needed for 50,000 tune up? (nightrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider &raquo;</TD></TR><TR><TD CLASS="quote">i'm a little passed 50k and i was thinking doing all my fluids and get a new timing belt to be safe. </TD></TR></TABLE>
Different fluids (engine oil, brake fluid, coolant, transmission fluid) get changed at different intervals; each one depends on the interval as well as on when you last had it changed.
Old Nov 7, 2004 | 04:40 PM
ebelp's Avatar
http://www.itrca.com/FAQ/maintenance/maint.php
Old Nov 7, 2004 | 06:14 PM
nightrider's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
exactly. i guess for me, i change the coolant, transmission fluid, and brake fluid around every 25k-30k. also, at the same interval i get my valve adjustment done.
Old Nov 7, 2004 | 07:19 PM
migs's Avatar
Whether if these are the official parts that need to be replaced or not, I would change out the:
1) distributor cap
2) distributor rotor
3) change all fluids: oil, water, transmission, brake fluid
4) use a cleaner that cleans the intake manifold, injectors and combustion chamber, typically it is a 3 step process
5) fuel filter
6) plugs
7) check your drive belts for fraying or cracking
8) air filter
Hope this helps.
EngineNoO9
Honda Motorcycles
23
Dec 27, 2006 04:38 PM
Bbasso
Sep 7, 2006 07:46 AM
b20turboteg
Apr 28, 2005 03:40 AM
01-0720
Oct 9, 2003 08:47 PM
rizen
May 3, 2003 11:12 PM
