All Honda Experts - Diagnose this symptom...
I feel like I'm losing power and the engine doesn't feel like it wants to rev as freely after about 1 hour drive. It only happens after driving about an hour. Also, there is no cel light or anything. After it cools, it runs fine again.
I'm thinking it might be some component that is about to break and only malfunctions under prolonged heat. Has anyone experienced this before? I'm thinking it could be either the Map sensor or the IAT. These components are the only things that I didn't replace during the swap.
plug fuel filter
plug cat like krazycivic said
check ur fuel pressure when the problem occures
does it smell like rotten eggs?(signs of plug cat)if not take it out and look through it
Radiator Fluid is new and fine.
Starts fine when it's hot.
I'm running test pipe.
Fuel Filter is brand new.
It's definitely not the effects of heatsoak because it feel a lot weaker plus I have cold air intake behind bumper.
I do have a B&M FPR so I'll check the fuel pressure next time it acts up and see if the pressure is correct.
Thanks.
Thanks.
