Looking for pic of GSR IAB system
Keyboard Humorist
Friend at work has an EG (I know this is the EF forum, but the question applies still) with a GSR swap.
It's being run with a P28 so the IAB is not hooked up.
I showed him how stupid easy it would be to add the 2 wires for IAB and run a P72 so I got him interested.
He didn't do the swap so he's not sure if the IAB system is even on the motor.
I want to go take a look at the car myself without fumbling around "guessing" where these parts are.
Anybody got pics of the vacuum diaphram location and the black canister/solenoid location under the manifold?
I used search... there were NO PICS, but lots of broken links and lots of info on how to wire them up.
Keyboard Humorist
Cool! Thanks!
Got another question.
I checked the tubing and it's all ran correctly for the IAB system.
I found a possible problem with the purge cut solenoind though.
In the pic on my previous post it shows a tube "12" going from the manifold to the purge cut.
On his car, the nipple on the intake manifold had a tube going from it directly to the charcoal canister.
A line goes from the canister to the purge solenoid like ti's supposed to.
Then the other hose for the purge (supposed to be "12") went to a T fitting that was put in line "17"
I would attempt to fix it, BUT where is the other line from the charcoal canister supposed to go? It's not shown in the pic.
alex37211
Oct 3, 2008 12:35 PM
4drEF
Nov 5, 2004 11:15 AM
Full Race A6
Audio / Security / Video
Jan 23, 2004 10:25 PM
