LS better to turbo!!
Old Dec 23, 2001 | 11:49 AM
Adampops's Avatar
Default LS better to turbo!!
Everybody says that an LS is better to turbo than a GSR because it has a lower cr. But, if you were to get lower cr pistons for a GSR than the GSR would be good to turbo also, right??
Old Dec 23, 2001 | 12:06 PM
OneThirtyEight's Avatar
Default Re: LS better to turbo!! (Adampops)
LS has a longer gear ratio, and has no VTEC which helps in really high HP turbo applications. It also has a longer stroke, a little more displacement and is easier to work on
[Modified by 97blackteg, 4:11 PM 12/23/2001]
Old Dec 23, 2001 | 12:43 PM
LSturboHB's Avatar
Default Re: LS better to turbo!! (97blackteg)
Thats what i have also heard too, i have also heard that is alot more complications with vtec.
I personly have a custom turbo on my LS in a civic HB. I decided to go with the LS cause its just a plug and play - no extra wiring.
----my 2 cents---
http://communities.msn.com/TurboLSHatchback
Old Dec 23, 2001 | 12:44 PM
hybrider's Avatar
yes it would be better suited for turbo if the comp is lowered
with the same amount of boost the GS-R will always come out on top, nuff said
Old Dec 23, 2001 | 12:48 PM
LSturboHB's Avatar
Default Re: LS better to turbo!! (hybrider93)
Gotta remmeber though TORQUE RULES!!!!!!!!!!!
degradated's Avatar
New User
With the same amount of boost, the GSR will have more hp, but I almost guarantee that the LS will have more torque
Old Dec 23, 2001 | 12:55 PM
BoM's Avatar
BoM
Default Re: LS better to turbo!! (degradated)
higher highpower also comes from the gsr better head....FLOWs much better
Old Dec 23, 2001 | 03:44 PM
xxplosif1's Avatar
Default Re: LS better to turbo!! (BoM)
....and you can always swap your b18b block for a b20z. Now YOU'LL have torque.
Old Dec 23, 2001 | 03:56 PM
Duck Sauce's Avatar
Default Re: LS better to turbo!! (xxplosif1)
People are always bragging about the VTEC. When in reality the GSR is only marginally faster than an LS. Stock for stock, an LS will easily run side by side with a GSR until 3rd gear.
Old Dec 23, 2001 | 04:16 PM
xxplosif1's Avatar
yup! One of my buddy was .3 faster then me with his GSR on the 1/4 mile....but now he went turbo....he is 2 seconds faster than me...lol
Old Dec 23, 2001 | 04:26 PM
Drag III Integra's Avatar
tq is where its at 3pds i dynoed to the wheels 169 hp and 165 tq. ls nice motor
Old Dec 23, 2001 | 04:30 PM
jinxproof99's Avatar
New User
Default Re: LS better to turbo!! (www.s4-mtm.com)
about 25 - 30 hsp to the wheels. plus the b18c1 has a better head, oil squirters, and bigger rods. oh, and revs 1000 rpms higher. i'd say thats pretty significant.
Old Dec 23, 2001 | 04:45 PM
Default Re: LS better to turbo!! (jinxproof99)
yeah but i ran gs-r's at the track with basically the same set up as them, even b4 i went turbo. so gs-r isn't that much better.
Old Dec 23, 2001 | 07:16 PM
TypeRInNeed's Avatar
New User
Default Re: LS better to turbo!! (Drag III Integra)
I dont know why you think that stock for stock an LS is just about as fast as a GSR. My friend has a GSR that i drive regularly and that thing kills stock, or slightly modded LS's.(His GSR is completly stock) And no way an LS can hang with a GSR all the way through 3rd.
Old Dec 23, 2001 | 07:42 PM
most of the GSR's little perks, like the above mentioned are great for small boosting, but when you want to go real high, you are not going to want them, thats why "most" of the big boys use the LS motors.
Old Dec 23, 2001 | 07:43 PM
thats not always true. When you are boosting seriously high the VTEC will hurt your performance more then help it, but MOST cases thats true, but not all.
Old Dec 23, 2001 | 07:44 PM
xxplosif1's Avatar
Default Re: LS better to turbo!! (TypeRInNeed)
hahahaha please...
Yes, a gsr is faster but there is no WAY a gsr will SMOKE an LS. With equal drivers, the gsr will be faster by .3 or .4 on the 1/4 mile.
The best i've seen with a gsr was 15 flat with a cold air intake and cat back system. I did 15.4 with my RS with only a CAI, i might be a kick *** driver after all.
[Modified by xxplosif1, 4:46 AM 12/24/2001]
Old Dec 23, 2001 | 07:51 PM
degradated's Avatar
New User
Now let's not get sidetracked here....We are talking about Turbocharged LSs and GSRs, not stock.....
Old Dec 23, 2001 | 10:00 PM
synergy004's Avatar
shoot, i am an avid nonvtec turbo guru, I love the B18A/B's the B18A1 built with turbo in my 92 HB is badass... I raced a GSR and we both are pretty decent driver, I only stayed with him until we shifted to 3rd which is about right ( this was naturally aspirated) now its a couple semi truck leads for me... If you lower the comp in any honda motor you will be able to run more boost depending on your fuel and air supply along with good tuning.. I did lower my c/r to 9.0:1.. So in being biased that yes VTEC is also baddass to boost as well.. I just say to hell with whos faster between an LS AND GSR>>> now when your spankin all the domestics then hell yeah it does matter there.. I ate a Mustang Rouch supercharged... When you start comparing your car to enemies instead of ALLIES then I rest my case. I say all honda motors are baddas when done right.
p out and happy holidays
crew synergy nationwide
Old Dec 24, 2001 | 05:06 AM
JCushing's Avatar
Thank you!!!!!!! finnaly soneone with common sense. the gsr isnt that much faster than an ls. the major reason why it isnt is the 3rd gear ratio. 1 and 2 are the same on ls and gsr. ive driven both and theres not a big defference.
Old Dec 24, 2001 | 07:09 AM
xxplosif1's Avatar
its like when people compare the b16a and the b18b....you can't unless both HAVE the same tranny. The tranny has a big effect on any motors, you have to have the right one.
B18B N/A: Sir or gsr trany
B18B FI: LS tranny
Old Dec 24, 2001 | 07:46 PM
New User
ok, maybe i got a little carried away with the whole "smoke" thing (lmao that was pretty stupid) but it is fairly easy to beat an LS by a good margin. yea yea i know were talking turbo here but i didnt bring up the almost stock racing in the first place. Ill be honest ive never drivin an LS, so im probably biased when it comes to comparing the two cause i love driving my friends car. So until i drive one ill just say they are both really great cars with plenty of potential using fd or not.
Old Dec 24, 2001 | 07:55 PM
I know I have a LS with around 200 hp at the crank, but I tend to fall behind a tad when I race modified preludes and **** in 3rd gear, LS tranny sucks for NA.
Old Dec 24, 2001 | 08:41 PM
ingrate's Avatar
25 Year Member
Default Re: LS better to turbo!! (JCushing)
the final drive is different.. GSR FD is 4.40 and the LS is 4.27 i believe
next time you drive that GSR, try going up to redline sometime..
Old Dec 25, 2001 | 08:41 AM
JCushing's Avatar
Default Re: LS better to turbo!! (In7egrity)
i have redlined a gsr (dealer car, hehe) there is a difference but not as big as alot of people make it out to be. both cars have there advantages. i chose a gs cause i wanted a good outa the box turbo car. that little bit of hp on top that ill loose i wont be worrying about when im burning clean through 3rd. someday......
alot of people just use words a little to liberally thats all and make the gsr out to be like a night and day difference from the ls.
