List of problems with my car!!! (RELATED TO ONE PROBLEM i think) HELP!!
I have a 98 integra gs-r. Thers a lot of problems with it. i just had replaced the clutch from a stock to stage 3 cllutchmasters(broken in like 2 weeks ago). Also i changed to a regeared ls tranny.
PROBLEMS:
1. Everytime i get off the clutch pedal and the car is in neutral it will make a weird grinding nosie that only goes away when i press down the pedal again. Could this be my throw out bearing???
2. My shifter is loose and i have trouble putting it in the second gear, "it goes but i have to use more power". Maybe i need a new shift bracket??
3. Everytime i shift into 3rd or 5th gear it will always grind!!! Only if i shift below 2rpm it will not grind.. Syncros????
4. Ever since the grinding i was just driving one day and next thing i know is that my car won't go in any gear and its stuck in gear even when i have it neutral. When i try to feed out the clutch and feed in the accelarator it still wont budge it will just bog and then stall. Shift linkage????
5. Lastly my v-tec isnt working i think its because my VSS isn't working. My speedometer doesn't work.
In case any of you guys are wondering i did try our "SEARCH" feature but it came up with little to nothing. thats why im asking you guys. If anyone here can help me out i would greatly appreciate it and if anyone has had any of these problems, please let me know what you did to fix them.
thanks
PROBLEMS:
thanks
