Wierd Tps Problems
Old Nov 5, 2004 | 03:21 AM
Curtis2kul's Avatar
Default Wierd Tps Problems
well im trying to hook up my vafc and i measured my tps voltafe at the tps and its around .25-.30 and it doesnt change when i move the throttle. why would it just go bad like that or is there a bad connection of some sort?
Old Nov 5, 2004 | 04:31 AM
drdisco69's Avatar
Default Re: Wierd Tps Problems (Curtis2kul)
If it works fine, then make sure you're testing the right wires.
Old Nov 5, 2004 | 05:28 AM
JODYG35950's Avatar
Default Re: Wierd Tps Problems (drdisco69)
usually the center wire is the one you need to tap. it should change in voltage as you rev. i think o to 6 volts dc
Old Nov 5, 2004 | 05:43 AM
crx_88_si's Avatar
Default Re: Wierd Tps Problems (JODYG35950)
0.4v to 0.5v for idle
4.5v (around there) for WOT.
Old Nov 5, 2004 | 12:24 PM
mannyman's Avatar
El Veterano de Sur Califas
i think you are tapping into the refrence wire on the tps(one of the outer wires). You need to tap into the middle wire as stated above. And i second that .5 idle, and 4.8-5.0 at WOT.
manny
giddyup21
Mar 18, 2012 06:49 PM
mouab18c1
Sep 18, 2010 05:09 PM
russ2169
Oct 24, 2009 03:55 PM
kholmes
Oct 12, 2004 06:59 PM
memphiss13
Jun 25, 2002 09:44 AM
