CEL Code on 2000 SI
I have a 2000 SI, and my check engine light came on after I installed a after market cat converter, but when I went to get it installed the mechanic said my O2 sensor was messed up and I needed to get a new one, and so I did and I fixed it. I reset the ECU and every thing was fine until after a while of driving the CEL came on again. The code it is throwing is 36 or 37. Does anyone know what that is on a 2000 model?
You sure you are reading those codes correctly. Double check them. There are no codes 36, 37 on a 2000 Si. There is a 63 (secondary 02) and a 73 (misfire #3) though. Check those codes again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danman3323 »</TD></TR><TR><TD CLASS="quote">I looked at those codes but thats not for a 2000 Civic SI.</TD></TR></TABLE>
Umm, yes they are, read.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">Yes those codes apply to all OBDI and OBDII vehicles. Not sure on the 01- up But covers all 92-00. What ecu are you running are you running the Orignal ECU or JDM?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmo »</TD></TR><TR><TD CLASS="quote">You sure you are reading those codes correctly. Double check them. There are no codes 36, 37 on a 2000 Si. There is a 63 (secondary 02) and a 73 (misfire #3) though. Check those codes again.</TD></TR></TABLE>
Don't mean to be mean, but again, did you read the link (not you, original poster). Good info.
-Shane
Don't mean to be mean, but again, did you read the link (not you, original poster). Good info.-Shane
Well, according to the link, there is no code 67. So, what you are saying is that it blinks long 6 times, then short 7 times? Between each code you should get a tiny break. Wait until the ecu repeats the first code. It will continue going through the codes over and over. You just have to watch carefully.
-Shane
-Shane
Here is a video of my CEL blinking, but what code is it?
http://www.geocities.com/danman3320/IMG00001.AVI
Register on http://www.we-todd-did-racing.com. You might have better luck getting the video up, seeing as though I couldn't view your vid on geocities.
-Shane
-Shane
Hmmm...yeah. I guess we don't know then. Like JDMlyfestyle said, he doesn't have that one on there and I have never heard of it. Maybe check with the dealer about that one. I would that thet should have every code available to man. Good luck. Sorry we couldn't help out.
-Shane
-Shane
Cablerat
Jul 31, 2007 07:03 AM
nissanjon
14
Jun 5, 2004 12:28 PM
