2002 HONDA ACCORD SE ECU HELP........
Old Nov 4, 2004 | 09:00 PM
eric817's Avatar
Default 2002 HONDA ACCORD SE ECU HELP........
I need help with my factory ECU box. I just installed it a few days ago and when I tired to start the engine, it would not turn over, Could anyone help me with this, is there any other things you must do after plugging it up. Do I need to reset the new ECU box,or what. Please give me your input on this.
Old Nov 4, 2004 | 10:28 PM
Stripped Honda's Avatar
99-0104
Default Re: 2002 HONDA ACCORD SE ECU HELP........ (eric817)
you must set the keys to the ecu the only way to do that is with a 6000.00 computer....... or you can tow the car to the dealer and let them program the keys for you ... my local dealer charges 82.95
Old Nov 5, 2004 | 06:59 AM
PrettyLude's Avatar
immobiliser system, yep the dealer has to program the chip in the key to work with your immobiliser
Old Nov 5, 2004 | 07:11 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eric817 &raquo;</TD></TR><TR><TD CLASS="quote">... it would not turn over...</TD></TR></TABLE>The immobilizer doesn't have anything to do with running the starter motor. Or did you really mean that it doesn't fire?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">immobiliser system, yep the dealer has to program the chip in the key to work with your immobiliser</TD></TR></TABLE>Actually, the chips in the keys can't be programmed. You program the immobilizer to accept the keys.
Old Nov 5, 2004 | 10:28 AM
lowboost's Avatar
Default Re: 2002 HONDA ACCORD SE ECU HELP........ (JimBlake)
I dont think that he actually meant that you reprogram the keys, but reprogram the immobilizer to the keys. But for sure you will be needing that done if it already hasn't been done. If not, make sure that you have all the clips in properly or maybe you sparked the computer when you installed it. (didn't disconnect the battery when removing/installing, could create a spark which computers don't like)
Old Nov 5, 2004 | 12:12 PM
b_ron007's Avatar
it should still turn over!
immobilizer just disables the fuel system.
does it even turn over? just wont start?
Old Nov 5, 2004 | 02:53 PM
eric817's Avatar
Default Re: (PrettyLude)
do you know how much that will cost to get done
Old Nov 5, 2004 | 02:57 PM
eric817's Avatar
Only the dealer can program the immobilizer and would you know how much that would cost
Old Nov 5, 2004 | 10:32 PM
99-0104
i just had mine done this week and it cost 82.95 ... at the dealer anyway ...
or you can call a locksmith and they can do it also but they charge 250.00 the good thing about a locksmith is that they will come to you without towing the car ...
the immobolizer is not a fuel cutoff it just doesent allow power to the distributor trust me i have experance in this ...
Chopstikz
Jan 11, 2008 07:10 AM
dbdragstar
Jan 19, 2007 02:47 AM
r1ch1e
Nov 19, 2005 06:32 AM
JDM.Sleeper
Jun 9, 2005 08:05 AM
phatrick2332
May 7, 2004 07:23 PM
