shocks..
Old Nov 4, 2004 | 06:15 PM
Honda-Evolution's Avatar
Default shocks..
hey, i had a interestin convo today with a machanic at my work. I asked him should i get coilovers or springs to lower my car and have a smooth ride with good handling? he told me b4 i look for those i should get shocks first cuz the shocks r what give u the smoothness of the ride. Is this tru? if so does anyone know any good brands that make good quality shocks?
Old Nov 4, 2004 | 06:20 PM
sexynuts(.)(.)'s Avatar
Well more or less yes it is true...after market springs with stock shocks will not give you a very comfortable ride. Suspension is one area that you want to invest some money into quality parts...if you want a comfortable ride you will probably want to go with springs as opposed to coil overs. Some good spring brands are Eibach, H&R, Tein, Neuspeed. If you want some excellent shocks to match the new springs get Tokico Illuminas or Koni Yellow's.
Old Nov 4, 2004 | 06:36 PM
CG2's Avatar
CG2
Default Re: shocks.. (Honda-Evolution)
i have skunk 2 coilover on my 2000 AV6 they ride okay but i need shocks too.... cause oem shocks will blow quick when u install lowering springs or coilovers, for the money i would reccomend tein basic damper set. ride height is adjustable, but if u want to adjust the damper of the shocks gett the ss version... peace
Old Nov 4, 2004 | 07:34 PM
Two_K Si's Avatar
Default Re: shocks.. (CG2)
Koni yellows with Ground Control coil overs/custom rate springs is a very nice setup, better than most pre-assembled coilover.
Old Nov 5, 2004 | 05:10 AM
sweet! thanks for the help guys
TigerLy
Jun 17, 2008 01:07 AM
b16ej1lsd
Suspension & Brakes
Oct 21, 2006 12:18 PM
DeL SLo
Apr 15, 2004 02:08 AM
slowman
Oct 27, 2002 10:09 AM
