intermediate shaft Q
I tried posting this in the hybrid section, maybe it was the wrong forum. I ordered my ZC engine and tranny, and it came with a free inermediate shaft, can someone explain to me what this does and where it hooks into the engine/tranny. Much help would be appreciated.
Thanks
Thanks
Well part of it bolts to the block and the shaft part goes into the tranny. You wont be needing that intermediate shaft unless you plan on using the zc tranny
Ok i just realized that you said you ordered a zc tranny also. So you will need to use that intermediate shaft
ok so I plug it into the block and zc tranny, then do the axels just plug directly into the tranny on one side, and then into the intermediate shaft on the other side ? If im understanding that correctly it makes it so I can just use the 91 integra LS axles (left side?) on both sides with no funky conversions or custom axles ?
Thanks
Thanks
Yes, one axle will plug from the passenger side and the other plugs in from the driver side. You'll notice that the inter shaft allows for equal length of the axles. As for which axles, I heard that 89 integra work as well as 90-93.
Too bad the search isn't work. I read on a configuration two weeks ago.
90-93 Integra axles - you need both right and left (not 2 of one side) - the driver's side inner CV joint has longer splines where it goes into intermediate shaft - the passenger's side has shorter splines and a smooth area that the seal in the transmission rides on - use 2 left axles and you will leak transmission fluid - 88-89 Integra are too short
Thanks for the info !!! I assume if I get the left and right shafts of a 90-93 that they will be the same length (except the splines) and will fit with no additional problems ?
Also I was planning on replacing the water pump, timing belt, and a few oil seals, anyone have a good link to a parts list so I can get them a head of time
Thanks again guys !
Thanks again guys !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gir »</TD></TR><TR><TD CLASS="quote">Thanks for the info !!! I assume if I get the left and right shafts of a 90-93 that they will be the same length (except the splines) and will fit with no additional problems ?
Thanks again guys !</TD></TR></TABLE>
Correct.
Try http://www.hondaautomotiveparts.com or http://www.slhondaparts.com for discounted OEM Honda parts.
Correct.
Here's a list of messages a saved...
https://honda-tech.com/zerothread?id=521434
I don't know where the thread is, but I copied the info:
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Bitch Pin Shift Linkage 91 crx si ???
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
Axles (S1 intermediate shaft) Integra '90-'91, any make (non-ABS).
Throttle Cable '90-'91 Integra, any model. Part # 17910-SK7-A03 (Acura)
Clutch Cable '88-'91 CRX Si, may require modification to fit.
Shift Linkage + Torque Rod '90-'93 Integra, requires modification to fit, or buy pre-cut (highly advised)
Clutch Disc Integra non-GSR, '90-'91.
Clutch Plate Integra non-GSR, '90-'91 (?????)
Throwout/release bearing Integra GSR, '92-'93 (?????)
Flywheel bearing Intergra GSR, '92-'93 (?????)
Cam seal endplug Part # 12513-P30-000
Oil Filter Integra GSR, '92-'93.
Valvecover Gasket Part # 12341-PR3-000. del Sol VTEC '94+.
Oil Pan Gasket Part # 11251-P30-004, del Sol VTEC '94+.
Intake Manifold Gasket Part # 17105-P30-004, del Sol VTEC '94+.
Exhaust Manifold Gasket Part # 18115-P30-013, Del Sol VTEC, '94+.
Rear coolant hose (IACV?) Part # 19507-PR3-000 (Honda)
Cam Seals Part # 91213-PR3-013 (Honda)
Cam seal endplug Part # 12513-P30-000 (Honda)
Spark plug tower seals Part # 12342-PG6-000 (Honda)
Valve cover grommets Part # 90442-P30-000 (Honda)
Timing belt cover gasket Part # 11831-PR3-000 (Honda)
Head gasket del Sol VTEC '94+
Fuel injector O-rings Part # 91301-PM7-003, del Sol VTEC '94+
Fuel injector rail cushions Part # 16473-PD6-000, del Sol VTEC '94+
Distributor Cap and Rotor Integra non-VTEC kit from Acura ('90-'91 Integra LS) Part # 06303-PR4-000
Water Pump Part # 19200-P30-003, from a '92-'93 Integra GSR.
Front + Rear Crank Seal Integra GSR, '92-'93.
Throttle body gasket Integra LS, '90-'91 (????). del Sol VTEC does NOT fit.
IACV seal CRX Si, part # 36455-PR4-A01
IACV CRX Si
Upper + Lower Radiator Hose del Sol VTEC, '94+.
Timing Belt Part # 14400-PR3-004, del Sol VTEC '94+.
Spark Plugs Part # BKR6E-11 (NGK copper) GAP: 0.039-0.043
Rear Transmission Bracket Part # 50827-SK7-020, '90-'93 Integra non-VTEC (80% sure)
Coolant hose, back of block to intake manifold Part # 19507-PR3-000, del Sol VTEC '94+.
(from my own experience)
https://honda-tech.com/zerothread?id=273030
Please review my parts list. I checked and double checked the rear main seal but have not installed it yet. Do you agree its the same??
I think this would be good to archive. I wish I would of had this list 6 months ago..
I went with everything
Water Pump 19200-P30-003 94 - del sol $86.28
Head Gasket 12251-P30-014 94 - del sol $57.56
Oil Control Orfice O ring 15142-PH3-003 94 - del sol $1.36
Intake Manifold Gasket 17105-P30-004 94 - del sol $8.26
Exhaust Manifold Gasket 18115-P30-013 94 - del sol $11.30
throttle Body Gasket 16176-PR3-010 90-91 integra $4.71
Pcv valve 17130-PM6-G01 94 - del sol $11.98
Timing Belt 14400-PR3-004 94 - del sol $48.72
Alternator Belt 31110-PR3-003 94 - del sol $7.56
Tensioner 14510-P30-003 94 - del sol $50.94
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same) $11.69
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same) $2.76
Cap & Rotor Assembly 06303-PR4-000 90-91 integra $24.54
Rotor (If needed seperately) 30103-PR3-016 90-91 integra $6.87
Clutch Cable 22910-SK7-A02 90-91 integra $45.54
Throttle Cable 17910-SK7-A03 90-91 integra $17.18
Cam Seals (2) 91213-PR3-004 94 - del sol $8.52
Oil pan seal 11251-P30-004 94 - del sol $18.64
Oil Filter 15400-POH-305 94 - del sol $4.93
Shift linkage bushing 54303-SB2-010 90-91 integra $4.66
crank seal 91212-PR3-003 94 - del sol $5.78
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same) $12.00
Valve cover grommets (8) 90442-P30-000 94 - del sol $20.80
Spark Plug O rings (4) 12342-P66-000 94 - del sol $7.16
Rubber plug for exhaust cam tranny side 94 - del sol $4.00
Spark Plugs (4) BKR6E-N11 NGK $8.00
Upper Radiator Hose 19501-PR3-000 92 - integra gsr $14.71
Lower Radiator Hose 19502-PR4-A00 90-91 integra FREE BY MISTAKE
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol $5.62
Washer for coolant drain on block 90401-PR4-000 94 - del sol $3.00
Thanks in advance for checking it over,
Monty
http://www.norcalcrx.org
1991 CRX SI
mileage = 123456
time to install the bee one six!~
A Write-up by blac_krix_si Taken from the Resource:
B16 parts list updated
Its seems the same exact questions have been coming up every 5 minutes, I took the B16A1 parts list that 88DXCRX provided and added a few things to it. The original is MIA since the site went down
*Distributor Locashracing.com has new OBDO for $275
*Distributor Hmotorsonline.com has used OBDO for $150
*Transmission Oil Seal. Beck/Arnley #0523545
Alternator Belt 31110-PR3-003 94 - del sol **this did not work for me, too long. I used the D16a6 Si belt**
*Shift Linkage Pin A94305-80222
*Shift Linkgae Pin Clip A54113-611-010
Valve cover grommets -8- 90442-P30-000 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK---- Stock Number 5724 in case they cant use the NGK #
*The rubber seal for the distributor cap is 30132-PM5-A02 (90-91 Integra)
*NAPA part #25-040300 for the alternator and a/c
Now, you don't need all of these parts to swap the motor. However it will be handy to keep this list saved on your hard drive if you ever need to replace anything on the motor.
Quote, originally posted by deftones0817 »
You need:
b16a tranny
b16a engine
b16a mounts for your car check with hasport
axles
wiring
computer
shiftlinkage for your setup
intake
header
exhaust
tools to do the swap
air tools help
k thats all i could think of off top of my head.
DEF
If you use 90-93 NON ABS Manual Integra Axles you will need a 90-93 NON ABS Manual Intermediate shaft.
ECU should be PW0 or PR3. PW0 is from the 1st generation SIR motor. PR3 is from the Integra XSI motor.
You don't need new exhaust, however it would be nice to replace at time of motor swap.
Some B16 motors come with factory header and downpipe. If it does not come with either, then you will need a header and downpipe. I happen to have 2 stock B16 headers and 1 stock downpipe. Your old D Series header will not fit on the B16 motor.
Also, if your current car is an HF model then you will need to upgrade your knuckles and hubs on your brakes to those from an SI or DX. I chose to swap the whole brake system over from a 91 Civic LX. Same as SI and DX basically.
Realistically, that is all you need, unless there are any sensors that need replaced on the B16. Not all B16's come to us perfect, but that's why you order from a respected seller like Hmotors or Nippon. Everyone has bad experiences so let's not make this a bash on JDM Motor distributors discussion.
Good luck and if you have any more questions feel free to PM me.
IACV CRX Si
Monty
1991 CRX SI
mileage = 123456
You need:
b16a tranny
b16a engine
axles
wiring
computer
intake
header
exhaust
air tools help
DEF
I appreciate all the input, but Im doing a ZC not a b16a
I wish I could do a b16 but its not in the cards currently.
Id love a huge list like that for a ZC swap tho :D
When putting in the I.Shaft just be careful not to loose any of those rollers, or any of those 3 pronged "things" i lost a bunch of them when i went ripping through my newly arrived engine. It's a paint o have to go finding them....or ordering them..
15221pw0s01, 15400poh305a, 17130pm6g01, 19501pr4a00, 9093, 91, axles, integra, intermediate, left, nippon, seal, shaft, side, transmission
