how to pu a 99 si strut bar onto an eg coupe
Old Nov 4, 2004 | 01:24 PM
jspresso's Avatar
Default how to pu a 99 si strut bar onto an eg coupe
have one and want put it on plus if any one has pictures please post them
Old Nov 4, 2004 | 01:30 PM
jspresso's Avatar
Default Re: how to pu a 99 si strut bar onto an eg coupe (jspresso)
bump
chad's Avatar
Moderator
Old Nov 4, 2004 | 01:31 PM
chad's Avatar
Moderator
Default Re: how to pu a 99 si strut bar onto an eg coupe (chad)
i replied but since you found the need to bump after SIX minutes i pulled the information down.....
Old Nov 4, 2004 | 01:34 PM
jspresso's Avatar
wheres the help man
Old Nov 4, 2004 | 01:37 PM
HATCHingMN's Avatar
it will bolt right in.
Your EG came predrill, just peel the sticker that over the hole up and you are ready to bolt in.
Old Nov 4, 2004 | 01:38 PM
H.crx-si
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i replied but since you found the need to bump after SIX minutes i pulled the information down.....</TD></TR></TABLE>
Thats helping the guy how? Maybe he already has the bar and is waiting for help to put it on right away......
boostedcivicsir's Avatar
Mr. Badwrench
there should be 2 plugs, on each side of your car at the strut tower. place the bar where it goes and you will see them. take out the plugs, nut and bolt voila. done. did it that way in the b-sir.
Old Nov 4, 2004 | 01:43 PM
H.crx-si
Guest
Posts: n/a
I have a 94ej (eg coupe if you like) and it has no predrilled holes like you guys are saying. You might have to drill your own holes.
Old Nov 4, 2004 | 01:44 PM
Mr. Badwrench
Default Re: (H.crx-si)
my hatch had the holes there.
Old Nov 4, 2004 | 01:47 PM
jspresso's Avatar
Default Re: (boostedcivicsir)
maybe its like that on the exs and si but i have a dx with probably everthing ex on it but no holes but thanks gies looks like ill just get drilling
Old Nov 4, 2004 | 01:50 PM
H.crx-si
Guest
Posts: n/a
mines a ex and still no holes......
Old Nov 4, 2004 | 01:51 PM
jspresso's Avatar
Default Re: (jspresso)
just check it looks like there might be some covered holes or like indents of some sort if someone has a closeup pic of one post it please it will be greatly appreciated
Old Nov 4, 2004 | 01:53 PM
Redline96LX's Avatar
* B A N N E D *
https://honda-tech.com/zerothread?id=972851
this may help, for a EK, but theory and work is identical.
Old Nov 4, 2004 | 02:29 PM
HATCHingMN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jspresso &raquo;</TD></TR><TR><TD CLASS="quote">just check it looks like there might be some covered holes or like indents of some sort if someone has a closeup pic of one post it please it will be greatly appreciated</TD></TR></TABLE>
on the shock tower,...there should be two hole predrill and cover up with match paint plugs. Just peel those off and you can bolt the strut bar in. If it dont came predrill then you will have to drill it yourself. But why drilling holes for a stock struct bar, when you can purchase some strut bar that can bolt onto the shock bolts that require NO DRILLING.
Jdmeg2kid
Apr 8, 2010 07:45 AM
90_Euro_R_cb7
Feb 25, 2009 12:50 PM
Wannbe Racer
Jun 8, 2006 10:37 PM
grandmasterflex
Apr 20, 2004 07:03 AM
Hybrid96EK
10
Oct 23, 2003 05:23 PM
