greddy turbo kit for 96-99 fit on a jdm 95 engine?
Old Nov 4, 2004 | 12:24 PM
Spins's Avatar
Default greddy turbo kit for 96-99 gsr fit on a jdm 95 gsr engine?
Any problems with this?
Old Nov 4, 2004 | 12:28 PM
DeadLock23's Avatar
Default Re: greddy turbo kit for 96-99 gsr fit on a jdm 95 gsr engine? (Spins)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spins &raquo;</TD></TR><TR><TD CLASS="quote">Any problems with this?</TD></TR></TABLE>
no, if you have a gsr, everything will bolt up, if you get the new kits with the e-manage then it will be fine once you retune it.
if you get a used or one from an older stock it will have the greddy blue box, which will need to be rewired for OBD1.
but everything is basically the same.
an LS kit differs in the charge piping and the downpipe the turbo, and manifold are the same.
Old Nov 4, 2004 | 12:33 PM
Spins's Avatar
Default Re: greddy turbo kit for 96-99 gsr fit on a jdm 95 gsr engine? (DeadLock23)
It will be a new kit with e manage. Reference. retune it. So I can't plug and play at first.
This will be in a 95 hatch back.
Old Nov 4, 2004 | 12:43 PM
Turbo E's Avatar
you may need to modify the downpipe. i did.
Old Nov 4, 2004 | 12:56 PM
Spins's Avatar
Default Re: (Turbo E 604)
was your dp too long or short? I'm worried more about the fuel management.
Will the greddy kit intercooler squeeze into the front nose of a eg hatch?
motive
Oct 17, 2008 09:54 PM
SOHC_2_DOHC
Oct 18, 2007 11:44 AM
bearboy80
Aug 15, 2004 09:17 PM
BlackB18CTeg
Mar 17, 2003 10:59 AM
jabroni95gsr
Feb 11, 2003 12:12 PM
