any1 have aem vs 2 and what are your thoughts on it
Old Nov 4, 2004 | 12:03 PM
AznInvasion's Avatar
Default any1 have aem vs 2 and what are your thoughts on it
i juss bought a used aem v2 for $100
and i have a brand new aem short ram intake
what do u guys suggest on i use on my gsr
i did a search couldnt really find anything
Old Nov 4, 2004 | 12:12 PM
LSvtec03's Avatar
Default Re: any1 have aem vs 2 and what are your thoughts on it (AznInvasion)
i guess it's ok, if you got it used for a hundred bucks.
i'd never buy a new one. $250 is insane for an intake when you can make one just as good yourself for 10 bucks. i never bought into that dual tube crap. plus you gotta move your ac lines or something. eff that.
Old Nov 4, 2004 | 06:51 PM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznInvasion's signature &raquo;</TD></TR><TR><TD CLASS="quote">94 boosted dc2
i gota question, why are you worrying about which intake to use when you have a boosted car?
those wont even fit
Old Nov 4, 2004 | 07:58 PM
Default Re: any1 have aem vs 2 and what are your thoughts on it (..::91TEG-G2::..)
taking my turbo off next weekend
tryint to get out of debt
Old Nov 4, 2004 | 08:25 PM
its really up to you.. with the v2, you cant use the bypass valve, if you wanted to..
and since your aem is only a sri.. it wont matter anyways.
but i think, im pretty sure that v2's are cold air
Old Nov 4, 2004 | 08:53 PM
a1320addict's Avatar
depends where you live...i live in jersey..climate sucks its always pouring unexpectedly...thats why i went for short ram...my boy got a v2.....car does pull a slight noticeable difference...but nothing i would risk hydrolocking over
Old Nov 4, 2004 | 09:06 PM
dt4life's Avatar
Default Re: any1 have aem vs 2 and what are your thoughts on it (yehiknowrite)
I suggest the stock intake system with a after market filter like spoon or greddy. The stock rubber arms disperse more heat then the AEM metal tubes. Plus you get a better throttle response off the stock system.
Old Nov 4, 2004 | 09:35 PM
SiR Inspired ED7's Avatar
Default Re: any1 have aem vs 2 and what are your thoughts on it (wannaTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannaTypeR &raquo;</TD></TR><TR><TD CLASS="quote">I suggest the stock intake system with a after market filter like spoon or greddy. The stock rubber arms disperse more heat then the AEM metal tubes. Plus you get a better throttle response off the stock system.</TD></TR></TABLE>
that's what my friend has done K&N works pretty good
Old Nov 5, 2004 | 03:59 AM
JustinG60's Avatar
Default Re: any1 have aem vs 2 and what are your thoughts on it (93 Da 16a)
V2 is cold air and you can not use a water bypass valve cause it makes the intake useless over a regular one... and according to the physics classes i have taken the intake should actually flow more air...
Old Nov 5, 2004 | 04:33 AM
97hatchback's Avatar
use the v2 it's a very good intake. My brother has one on his gsr and he loves it.
Old Nov 5, 2004 | 08:44 AM
Default Re: any1 have aem vs 2 and what are your thoughts on it (97hatchback)
i has 2 peices to make it cold air or short ram for the v2
i will prolly just use it as a ram air
Old Nov 5, 2004 | 09:59 AM
_WhItE_97gSr_'s Avatar
I have a V2 on my 97 gsr and I like it. No problems yet. Just avoid big puddles of water and you should be just fine. Especially if your car is lowered.
Old Nov 5, 2004 | 08:01 PM
Das Nuge's Avatar
Just got mine last month brand new for $165.
Does anyone else's V2 hum when the car is idling? Mine does .
Also, if I press the gas down a certain amount, it whistles. Anyone else?
All in all, I like it a lot.
Old Nov 6, 2004 | 03:09 PM
GSR_Jamee's Avatar
Default Re: (B18C1_DN)
ive got the V2 in my 98 GSR and i like the fact that its visually intimidating.
downside: its a B*TCH to put in. (especially cuz i ve got the stock & DC strut bar)
upside: it makes my car sound mean, if im gunning it and yer outside listening, especially when VTEC kicks in @ 4500
AEM V2 vs SRI
V2 = cai = better for freeway racing/ top end
SRI = better throttle body response for short races/low end
Old Nov 7, 2004 | 05:13 PM
Default Re: (GSR_Jamee)
i decided to go with the short ram since the V2 doenst fit my gsr
it hits the tranny for some reason
so its up for sale
Old Nov 17, 2004 | 06:11 AM
jdm96dc2's Avatar
Default Re: (AznInvasion)
how much u tryin to get for it? n do you got pics?
Old Nov 17, 2004 | 06:54 AM
tumbleweed's Avatar
Default Re: (jdizzle00)
I have taken my car to the dyno and did 3 dyno pulls with a regular AEM cold air intake and then I did another 3 pulls with the V2 intake and I had a 3whp gain total a the peak curve started at a lower rpm. SO I can say that the V2 is a great intake.
Old Nov 29, 2004 | 09:30 AM
PaChiLa Leader's Avatar
Default Re: (tumbleweed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tumbleweed &raquo;</TD></TR><TR><TD CLASS="quote">I have taken my car to the dyno and did 3 dyno pulls with a regular AEM cold air intake and then I did another 3 pulls with the V2 intake and I had a 3whp gain total a the peak curve started at a lower rpm. SO I can say that the V2 is a great intake. </TD></TR></TABLE>
sounds good.. V2 is what i am gonna get for my next mod
Old Dec 2, 2004 | 10:48 AM
CompanyFlow's Avatar
Default Re: (PaChiLa Leader)
You can technically build your own V2. Just order 2 of the extensions for it and put them together, and pop on any filter you want. Cheaper, and you have yoru choice of filter
Old Dec 2, 2004 | 12:15 PM
lVlemphizStylez's Avatar
Default Re: (CompanyFlow)
thats very true...a lot cheaper too... for spending over 30 bucks on pipes and a foam filter [which got you at most 5 whp]
vollrathian
15
Aug 29, 2006 12:29 AM
Lookincrazy
Honda S2000
22
Jun 13, 2006 05:14 PM
NinjaTech
24
Mar 30, 2005 03:57 PM
silly_lil_nate
Jan 23, 2005 07:15 PM
brownman72000
Aug 10, 2003 02:23 PM
