89 civic clutch dx motor si tranny put it clutch
If you don't know what the **** you're doing (which it appears you don't), take it to a shop and have them do it for you.
Seeing how you dont have any knowledge on this I assume you never did it before
there is alot more to it then you are thinking...axles come out,shoft linkage,unbolt the tranny disonect hoses and wiring and clutch cable and speedo cable and mounts etc.... drop the tranny replace and align the clutch put everything back together (alot of little misc things) dont have a sight for you to get instructions but dude your better off taking it to a shop cause I can tell your prob not capable of doin this....Not trying to sound like a dick but it is going to be more of a problem when the thing is half out with parts all over bolts all over and no clue on how everything is supposed to go back together
buy a service manual. read it. if you think you can do it, try it. if it seems to complicated, get help from someone that knows what they are doing, or take it to a shop.
wow....people on honda-tech are a bunch of ****** **** (BauleyCivic)
hey man, jsut go to like kragens or autozone and get a helms, take a look in it and check out what youll need to be doing. if you think you can do it, try it on for size(but have a back-up car ready) if you cant, ask someone to help you. its pretty straight forward(you will know what i mean when your doing it) if not have a friend help ya out....peacem an, and good luck
PINKS
12
Jan 14, 2006 06:05 AM
