85 CRX carb need help ASAP!!!!!!!!!
Old Nov 4, 2004 | 11:01 AM
vtecn8ive's Avatar
Default 85 CRX carb need help ASAP!!!!!!!!!
Hey I need to find some information on how to convert a 85 Crx Carberated to Fuel Injection. (plan on either putting a b18a1 or b18b in it). Please give me direct links not to homepages. if anybody can help me one on one that would be best let me know guys. You have helped me before when I did a b18a1 in my 91 CRX Si now I want to go even more old school .
-Shane
Old Nov 4, 2004 | 11:04 AM
mrspeaker's Avatar
Default Re: 85 CRX carb need help ASAP!!!!!!!!! (vtecn8ive)
Look for a 84-87 civic/crx SI in a junkyard and take the intake manifold,ecu,wiring,everything..
I helped my friend convert his 85 mustang 5.0(carb) to 87-93 5.0 spec (FI)
What a pain in da ***.. So many extra wires
Old Nov 4, 2004 | 11:15 AM
vtecn8ive's Avatar
Default Re: 85 CRX carb need help ASAP!!!!!!!!! (Mrspeaker)
What needs to be done for the b18a1...
1. Fuels delivery?
2. Wiring?
3. Engine mounts?
4. Axles?
5. Is there any cutting of the frame, body??
Pretty much I know a lot more about 88-00 civic/crx and 90-01 Integras.
I know nothing (well damn near nothing) about carberuators. I really don't know to much of the pre-88 CRX . About 3-4 months ago I didn't know sh*t about CRX's now I have 2 engine swaps done all by myself. I know a lot of what will and won't work for the CRX's just not any before 88.
-Shane
Old Nov 4, 2004 | 11:37 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
http://www.redpepperracing.net
go there they are the 1g specialists, i used to use that forum when i had my 1g
Old Nov 4, 2004 | 11:59 AM
Blaze45's Avatar
Brrraaaap!
Default Re: 85 CRX carb need help ASAP!!!!!!!!! (b2o-vtec)
Actually its http://www.redpepperracing.com It is THE best web site for 1st gens. They will be able to help you. Good Luck!
Blaze
Old Nov 4, 2004 | 01:10 PM
vtecn8ive's Avatar
Default Re: 85 CRX carb need help ASAP!!!!!!!!! (Blaze45)
Anybody got direct links? I have been checking out that site today but couldn't figure it out. I'll check it out again later.
-Shane
Old Nov 4, 2004 | 01:24 PM
wtsexton's Avatar
You'll need a bunch of things.
Fuel lines,
Si tank with pump,
Wiring harness.
I've got a complete wiring harness from a 86 Si.
Headlight to tail light including dash harness.
May not need it so I may let it go for a price.
Old Nov 4, 2004 | 03:03 PM
vtecn8ive's Avatar
Default Re: (wtsexton)
I've read of people keeping there stock fuel except the filter and pump and the hoses. I guess the difficult part is where to mount the si fuel pump.
Wire Harness yeah I'm definately going to be on the look out for a complete SI harness.
Anybody else??
Old Nov 4, 2004 | 06:47 PM
vtecn8ive's Avatar
Default Re: (vtecn8ive)
Anybody else help me out?? What ecu to run? will 90 integra wiring work in a 85 CRX??
-Shane
Old Nov 4, 2004 | 07:44 PM
wtsexton's Avatar
You can not use the stock fuel lines because they can not handle the pressure needed. Also there is no fuel pump once you remove the stock engine because the fuel pump is mounted to the engine. I'd stick with using wiring for the same model.
Old Nov 4, 2004 | 07:48 PM
vtecn8ive's Avatar
Do you know if the fuel lines run below the car or the inside of the car? Where is the fuel pump on it when I remove it (just curious)? I will plan on sticking with the same model then I was just wondering.
Thanks for the help.
Old Nov 4, 2004 | 08:10 PM
87sivtec's Avatar
I just finished a carb to fi swap with a B16 into a 1987 Crx. PM me for more info.
You can use some of the stock fuel lines. I used the carb feed line as the new f.i. return line. I left the tank vent line the same and added a new Si feed line. I used a Si pickup/sender in the HF tank as well as the Si pump in the stock location. You will have to make some sort of mount for it there.
The lines are all inside the car along the left frame rail.
An Si wiring harness is easiest as well.
Check out the info on hasports site.
http://www.hasport.com
Old Nov 4, 2004 | 08:19 PM
vtecn8ive's Avatar
Default Re: (87sivtec)
Could you go in depth on what you had to do to convert it to a Carb-FI? Or could you post some pics or send me some pics. I'll IM you with the same questions.
-Shane
Thanks.
Old Nov 5, 2004 | 03:45 PM
vtecn8ive's Avatar
bump still need help.
Old Nov 5, 2004 | 03:49 PM
shadowboy's Avatar
you have a LOOOONG road ahead of you.
there is much to do. it's not a swap for a beginner.
i speak from experience as i have a black top D16A1 in my 87 HF.
Old Nov 5, 2004 | 04:19 PM
vtecn8ive's Avatar
Default Re: (shadowboy)
lol yeah i am aware of it. I plan to do the swap in it next summer. I just want to now what to get over the winter.
HELP!!!!!
Old Nov 7, 2004 | 11:02 AM
vtecn8ive's Avatar
bump checked out the car has minor stuff that needs to be done but I am going to get it as long as I sell my 91 CRX Si w/b18a1 w/S1 tranny (PM me if you can beat 1300!!).
So I need to know how to do this. Is there a fuel filter on a carb engine or will I need to add one?
-Shane
SE3Pimp
Jul 14, 2006 02:31 PM
NO PRESSURE
33
Nov 4, 2004 04:45 PM
jetydosa
May 9, 2003 03:21 PM
Aquafina
Feb 5, 2003 04:29 PM
