just installed my act clutch
Old Dec 22, 2001 | 10:12 PM
vpforeva's Avatar
New User
Default just installed my act clutch
at first i drove the car the clutch pedal felt squishy and stuff like the liquid in the master cylinder is low, so then i drive along later and my clutch pedal fell right to the floor? so i got down and pulled back up the clutch pedal and then it was fine like how it is to be, what could be the problem? did the problem fix it self?
Old Dec 23, 2001 | 01:57 PM
prelude1897's Avatar
Default Re: just installed my act clutch (vpforeva)
So what you are saying is that your clutch works now? If it does it again, you may want to check your master cyclinder or your slave cyclinder next time. Those usually tend to go out.
Old Dec 23, 2001 | 03:18 PM
Backyard Speical's Avatar
there might be some junk air that you need to clear out in the master cylinder or the lines.
Old Dec 23, 2001 | 03:25 PM
JG Luder's Avatar
Default Re: just installed my act clutch (Prodigy 2.2 EK)
yeah, I'd bleed the lines if you didn't do it to begin with!
Old Dec 24, 2001 | 12:24 PM
irdprelude's Avatar
hey the same thing happened to me...only the pedal didnt come back up to the normal position.
check your slave cylinder...that is what was wrong with mine.
Old Dec 24, 2001 | 01:20 PM
mike's Avatar
H-T Order of Merit
Bleeding your clutch system will fix this.
Mike
skhell
Transmission & Drivetrain
Jun 23, 2010 12:11 AM
Hill4589
May 21, 2009 05:41 PM
hannslebo
Mar 24, 2009 01:53 PM
FLCivic
Jun 30, 2004 03:48 PM
g00se
Mar 8, 2004 06:11 PM
