4.785 final drive ?
Old Dec 22, 2001 | 09:23 PM
da6vtec's Avatar
Default 4.785 final drive ?
what parts do i need to fit a 4.785 final drive and honda lsd into a 92 gsr cable tranny? any help would be greatly appreciated.
[Modified by da6vtec, 10:33 PM 12/22/2001]
Old Dec 22, 2001 | 09:49 PM
da6vtec's Avatar
Default Re: 4.785 final drive ? (Mr. JDM)
will it fit is what i mean...i've heard elsewhere that the cable tranny casings are different than the hydro trannies. what is all included in the final drive kit exactly?
Old Dec 23, 2001 | 04:33 AM
Reid's Avatar
Global Moderator
Default Re: 4.785 final drive ? (da6vtec)
Actually a 92-93 GSR tranny (YS1) should internally be like a hydro tranny, meaning that any parts applicable to hydro trannies will work on your tranny.
Old Dec 23, 2001 | 06:19 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: 4.785 final drive ? (Reid)
Okay, if you will dp a search on 4.785, or final drive, etc. you will get a slew of results.
I'll tell you what comes in the kit:
(1) Ring gear (the actual final drive gear)
(1) Pinion shaft (the shaft that rides against the ring gear - also houses 1st gear, reverse, and one side of 2-5 gears on it)
(1) JDM first gear (same ratio as USDM, but inner size is different)
(1) Distance collar (fits the 1st gera properly)
(2) Needle bearings ( 2 halves = 1 whole bearing for the first gear)
I've personally got the ATS 4.929 final drive in my ITR swap and I LOVE it. Do a search to find different topics that compare the 4.929 to the 4.785, and to get others' impressions of their own FDs after installing them.
Hope that helps.
mrx
18
Feb 25, 2013 05:21 AM
gilou bilou
Nov 11, 2005 09:05 AM
Terrible One
Nov 10, 2004 01:34 PM
SuperNouva
Sep 19, 2004 10:32 AM
DJCujo69
Aug 12, 2003 09:08 AM
