estimated power
Old Nov 4, 2004 | 08:51 AM
qcktegls's Avatar
Default estimated power
i dont have enough money to build a turbo that wont kill me engine over time. i have i/h/e on my 95 ls. i have about 2 grand to build on. what kind of hp gains can i expect with cam shafts and gears, intake mani, and tb? also thinking about pistons and rods but torn on what to do with money. thanks
Old Nov 4, 2004 | 10:47 AM
Supahatch's Avatar
Default Re: estimated power (qcktegls)
save another g and get GSR swap...
Old Nov 4, 2004 | 11:47 AM
StolenTeg's Avatar
Default Re: estimated power (Supahatch)
2000 is enough to built a turbo set-up, research and find out what you need and dont need. Remember not to go cheap on EMS...
Old Nov 4, 2004 | 01:24 PM
Calsonic's Avatar
You could sell your header and make some money. If you want power, turbo is the way to go. Just remember to get it tuned so your motor won't prematurely die on you.
Old Nov 4, 2004 | 01:32 PM
m0nk's Avatar
2k!? get a gsr head, itr cams, and build the head to handle u'r 8500 redline.
Old Nov 4, 2004 | 01:53 PM
integra4991's Avatar
If you dont wanna go turbo but dont wanna spend a ton of cash you could always go with a basic ls/vtec setup, but i think boost is deffnitly the way to make power on a ls. i put my kit togeather for about 1400 (not tuned or anything yet though).
Old Nov 4, 2004 | 01:59 PM
notstock93's Avatar
Default Re: estimated power (integra4991)
boost it at a low PSI and enjoy it.
LS+boost= torque monster.
I wish I had boosted my LS from the beginning.
Old Nov 4, 2004 | 03:43 PM
qcktegls's Avatar
i have been thinking mostly to go towards the ls-vtech conv. If i go with that will the golden eagle kit come with everything to set it up? and what other parts would i need to buy to make it more reliable and quicker? Some search threads have said that valve springs should be put in cause after a couple years the engine could go. thanks for all the help fellas
Old Nov 4, 2004 | 03:51 PM
a1320addict's Avatar
Default Re: (Calsonic)
go all motor
cams, gears, mani, high compression pistons, rods, and some form of engine management
Old Nov 4, 2004 | 05:30 PM
usdm420's Avatar
816d16 owes me money!
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: (yehiknowrite)
2G's...LS motor
ITR pistons ($300 w/rings)
shot peened stock rods (about $100)
crower 403's ($600)
valvetrain upgrade ($500 + $125 for good timing belt)
header/exhaust/tb and that should be about $2G's nicely....get it all done at once at a decent shop to get the best deal
BTW, try and sneak in a b16 tranny
Old Nov 4, 2004 | 06:52 PM
HONDA_TYPE_R's Avatar
Default Re: (usdm420)
2g's...Golden Eagle ls/vtec kit.
CTR Pistons
Crower rods
ITR cams and valvetrain
Shop work
Tuning.
You could also look into getting an AN-R header...they run around $530 shipped with a street collector. Seen dyno's of them making 8whp over an ITR header. Really high quality.
Old Nov 4, 2004 | 07:01 PM
Oleg's Avatar
get the aftermarket ECU(like Hondata or smth) plugandplay mode one.....it is expensive, i know, but it is the only thing that can get the horsepower out of your i/h/e setup right now.....the maps that stock ecu running right now are really ineficcient. You have to buy ECU, this is the only way you can modify your car perfomance, without it you can only damage the engine, or get smallhp gains.....furthermore, you will need ECU anyway with camshafts and stuff(to get the most out of them)
Old Nov 4, 2004 | 07:13 PM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdm420 &raquo;</TD></TR><TR><TD CLASS="quote">2G's...LS motor
crower 403's ($600)
BTW, try and sneak in a b16 tranny </TD></TR></TABLE>
I think more along the lines of:
$2K...LS Motor
Non-vtec route:
CTR Pistons....$280 w/ rings
Crower 404 or 405 cams....$350
Crower Valvetrain....$300
Skunk2 mani....$250
Bore out TB(64mm)....$100(maxbore.com)
B16 tranny....$600
That so far equals: $1880
Now all you need to choose is a good header and Intake!
IMO with $2K in your pocket you can build your motor how you want it! You have 3 options: Vtec, non-vtec, or turbo! So do what you want!
Old Nov 4, 2004 | 07:28 PM
Integrt's Avatar
Default Re: (hybrid_vtec)
nice sig hybrid_vtec im glad bush won also.. i hate alll the pansy solider downers
if it wasn't for the military wed all be dead
Old Nov 4, 2004 | 07:29 PM
Integrt's Avatar
anyways go for boost u won't regret it on a LS
Old Nov 4, 2004 | 08:58 PM
Default Re: (Integrt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integrt &raquo;</TD></TR><TR><TD CLASS="quote">nice sig hybrid_vtec im glad bush won also.. i hate alll the pansy solider downers
if it wasn't for the military wed all be dead</TD></TR></TABLE>
Glad some ppl still see it that way! Thanx
All the ppl bitching are the reservists, b/c they just signed up for the $ and benefits and dont want to do their job when called upon!
Old Nov 4, 2004 | 09:10 PM
PhantomSTi's Avatar
Default Re: estimated power (notstock93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notstock93 &raquo;</TD></TR><TR><TD CLASS="quote">boost it at a low PSI and enjoy it.
I wish I had boosted my LS from the beginning. </TD></TR></TABLE>
He's right, my tq numbers are bigger then my hp numbers !
Old Nov 5, 2004 | 10:25 AM
qcktegls's Avatar
Default Re: (HONDA_TYPE_R)
I have a greddy 4-1 header and a greddy evo exhaust with aem cai intake. id love to do the ls/vtec conversion cause the yelling of the vtec. i dont have enough cash to go boost cause if u do boost u should do i right. how much would the shop charge to do all that work including tunning for the car? and would i want a hondata s100? my friend has a megasquirt if nebody has ever heard of that and will sell it to me cheap. thanks for the answers. its greatly appreciated
Old Nov 5, 2004 | 11:05 AM
qcktegls's Avatar
Default Re: (qcktegls)
https://honda-tech.com/zerothread?id=501372
that thread right there is one of the reasons the v-tec conversion scares me a little. i cant afford a new engine if it messes up. ill spend the cash to do it right the first time.
So far i need:
golden eagle kit
CTR pistons
Crower rods
Cams
Valvetrain
Intake Manifold
TB 64
hondata s100
shop work and tunning
(lookin for a b16 tranny to)
If there are more parts that i need so that it will run great let me knokw. thanks
Old Nov 5, 2004 | 11:09 AM
Kowalski's Avatar
Go turbo
Crave4Knowledge
Jan 12, 2016 12:01 PM
RighteousRyano
Aug 17, 2006 12:21 PM
Honda Harles
May 10, 2005 06:50 AM
Mr.Saturn
Aug 3, 2003 08:16 AM
95b18b
Dec 23, 2002 01:21 AM
