what years? gsr header without o2 sensor
Old Nov 3, 2004 | 11:55 PM
siblue_gzer's Avatar
Default what years? gsr header without o2 sensor
i have a 96 gsr, and my stock header doesn't have an o2 sensor. i bought one from a guy out of state and his had an o2 sensor. is his a obd1?
Old Nov 4, 2004 | 12:17 AM
sPaRk'iT's Avatar
Default Re: what years? gsr header without o2 sensor (siblue_gzer)
Correct me if im wrong anybody, obd1 gsr has two sensors, one on the header and one on the cat, obd2 gsr i think have both sensor on the cat. Something like that i dont quiet remember. If not then probably the stock header you bought is not from a gsr...
Old Nov 4, 2004 | 04:03 AM
JimBlake's Avatar
Default Re: what years? gsr header without o2 sensor (sPaRk'iT)
No, OBD-1 GSR only has one sensor. But it's in the inlet of the cat. So the header doesn't have a fitting.
The 2nd sensor for OBD-2 cars is AFTER the cat...
Old Nov 4, 2004 | 04:28 AM
loud_whispers's Avatar
Default Re: what years? gsr header without o2 sensor (JimBlake)
No.
OBD-I and OBD-II cars both have heated o2 sensors on the collector end of the exhaust manifold. OBD-I cars do not have an o2 sensor on the catalytic converter. OBD-II cars DO.
So,
OBD-I = 1 sensor on the exhaust manifold.
OBD-II = 2 sensors, one on the manifold and one on the catalytic converter.
OBD-I = anything before 1996 ( 1993/1994/1995)
OBD-II = 1996 and anything AFTER ( 1996,1997,1998..etc..)
Old Nov 4, 2004 | 05:38 AM
JimBlake's Avatar
Default Re: what years? gsr header without o2 sensor (loud_whispers)
OBD-I GSR doesn't have the same exhaust as an LS. It has a shorter A-pipe, & the catalytic converter has a longer inlet section. The O2 sensor is in the cat housing, but it's upstream of the monolith.
The A-pipe for the B18B is longer, so the sensor is in the A-pipe. Either way, the sensor is pretty much located in the same place w.r.t. the firewall/floorpan.
They changed that configuration a couple years after OBD-II, so the redesigned A-pipe doesn't exactly correspond with OBD versions.
Old Nov 5, 2004 | 02:31 PM
so the one with the o2 sensor on the header could be from an LS?
Old Nov 6, 2004 | 06:07 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblue_gzer &raquo;</TD></TR><TR><TD CLASS="quote">so the one with the o2 sensor on the header could be from an LS?</TD></TR></TABLE>Or a newer GSR. I don't remember what year the GSR switched over to having the O2 sensor in the A-pipe.
Old Nov 6, 2004 | 06:52 AM
92integra_gs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loud_whispers &raquo;</TD></TR><TR><TD CLASS="quote">No.
So,
Old Nov 6, 2004 | 07:36 AM
Rory Breaker's Avatar
Default Re: what years? gsr header without o2 sensor (92integra_gs)
This is incorrect.
OBD1 GSR - 1 02 SENSOR ON THE CAT
OBD2 GSR (96-99) - 2 02 SENSORS ON THE CAT
OBD2 GSR (00-01) = 1 02 SENSOR ON THE HEADER, 1 02 SENSOR ON THE CAT
SlammedBlackGSR
Oct 14, 2006 06:57 PM
92b18cx
Jun 1, 2005 01:03 PM
tyflip2
Jun 16, 2004 10:45 PM
colombian linx
Feb 3, 2004 08:57 AM
Rob Dizzle
Nov 30, 2001 10:46 PM
