CAR OVERHEATED!
Old Nov 3, 2004 | 10:46 PM
m0nk's Avatar
Default CAR OVERHEATED!
ok so i've been driving pretty hard all day, and i'm driving up this steep as hill and when i park i notice steam coming out of my hood, i look down at my watertemp and its 3/4 to the red line...the smoke had a sweet smell : \
i recently installed new sparkplugs and read somewhere that overtightening them can cause u'r engine to overheat...although, my friend (who's pretty car savvy) said that if the smell is sweet it might be an engine coolant problem...please help!!!
...btw, i have a 95 teg ls.
Old Nov 3, 2004 | 10:51 PM
m0nk's Avatar
Default Re: CAR OVERHEATED! (m0nk)
btw...i heard a buzzing/grinding noise from teh engine bay--can't be good...
Old Nov 3, 2004 | 11:29 PM
siblue_gzer's Avatar
hey it could be your water pump. does your car still overheat though? if it does then that could be it. mine was the same. i heard something clicking and then temp went up. and everytime i drive it goes up. anyways, check that out, if not that then it could be the thermostat
Old Nov 4, 2004 | 12:43 AM
fuzzie's Avatar
Default Re: CAR OVERHEATED! (siblue_gzer)
yea..might be a water pump...my car was over heating..soo i check my radiator..no coolant..it all leaked out my water pump HA
Old Nov 4, 2004 | 01:24 AM
jdm-civic's Avatar
Default Re: CAR OVERHEATED! (fuzzie)
what do u guys usually do if the car over heats like this? let it cooldown then replace it asap?
sorry noob here...
Old Nov 4, 2004 | 07:04 AM
dick_213's Avatar
Default Re: CAR OVERHEATED! (jdm-civic)
turn on your heater full blast to take as much heat out of the heater core as possible. but the best thing would be just to pull over.
Old Nov 4, 2004 | 07:07 AM
Stripped Honda's Avatar
99-0104
Default Re: CAR OVERHEATED! (dick_213)
first theing you need to do is a radiator pressure test to see where the leak is from then you will have a better idea what the problem is ...
and overtightening plugs will only cause stripped threads not overheating ...
nychonda
Jul 31, 2012 10:20 AM
0ni
Dec 21, 2009 04:42 PM
musTerdh22eg
Feb 4, 2006 11:53 AM
HondAcura
Sep 26, 2005 12:19 PM
-iLLuZioN-B18C1
Nov 8, 2004 07:26 AM
