help!!! check engine light went off
Old Nov 3, 2004 | 10:00 PM
JDM_Type-R's Avatar
Default help!!! check engine light came on
basically i was just cruising like 40 mph and all of a sudden it goes off.
its never gone off before, and i have about 40K miles on it. it idles fine, and everything seems fine..but i cant seem to find out what caused it. does anybody have a clue what it is, or what it could possibly be? any info appreciated. thanks so much.
Modified by JDM_Type-R at 12:39 PM 11/4/2004
Old Nov 3, 2004 | 10:06 PM
B2FiNiTY's Avatar
Default Re: help!!! check engine light went off (JDM_Type-R)
Check the code y0.
http://www.c-speedracing.com
Old Nov 3, 2004 | 11:26 PM
JDM_Type-R's Avatar
Default Re: help!!! check engine light went off (B2FiNiTY)
k so i found out it was code 67..and its "Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system"
so basically a bad cat...?
do i even need to replace it?
Old Nov 4, 2004 | 12:42 AM
Slow_Em1's Avatar
get an obd1 ecu, and jumper, there will be an indefinate code of "nonexistant" after that. LOL
thats my way of solving things these days, i swear im fuckign lazy
good luck
Old Nov 4, 2004 | 05:21 AM
jeremy.'s Avatar
Default Re: help!!! check engine light went off (Slow_Em1)
same here haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_Em1 &raquo;</TD></TR><TR><TD CLASS="quote">get an obd1 ecu, and jumper, there will be an indefinate code of "nonexistant" after that. LOL
good luck </TD></TR></TABLE>
Old Nov 4, 2004 | 11:23 AM
JDM_Type-R's Avatar
Default Re: help!!! check engine light went off (ekay_jeremy)
driving the car won't harm anything right? this sucks...first time carsound started rattling..now it makes the check engine light go off...carsound blows
Old Nov 4, 2004 | 11:26 AM
yoshi234's Avatar
I shoot brides
f0k MIL's!
i'm driving w/ #67 and #1467 codes
Old Nov 4, 2004 | 11:27 AM
nightrider's Avatar
carsound cats are good, but since R's run rich, it will definitely go out sooner than expected. if you get her tuned, i'm sure the cat will last lots longer.
Old Nov 4, 2004 | 11:33 AM
emotionisdead's Avatar
Very Emergency!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Type-R &raquo;</TD></TR><TR><TD CLASS="quote">k so i found out it was code 67..and its "Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system"
do i even need to replace it?</TD></TR></TABLE>
do you have a high flow cat? mine threw that code all the time. the reason for the code is that obdII cars measure the differnece in exhaust gases from the first to the second o2 sensor. if the second reads too close to the first one, check engine light. the car will run fine, it is not a limp mode code. i solved my problem by getting a obd1 kenji chipped ecu and jumper harness
Old Nov 4, 2004 | 11:34 AM
Jon D's Avatar
So wait a minute....j00 are complaining about it going off? If i were you i'd be happy it FINALLY went off
Edit: after re-reading the title...i think you ment "check engine light has come on" , right?????
Old Nov 4, 2004 | 11:37 AM
ebelp's Avatar
Default Re: help!!! check engine light went off (B18C-Rsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C-Rsi &raquo;</TD></TR><TR><TD CLASS="quote">So wait a minute....j00 are complaining about it going off? If i were you i'd be happy it FINALLY went off
Edit: after re-reading the title...i think you ment "check engine light has come on" , right????? </TD></TR></TABLE>
I was thinking the same thing. I'd love it if my check engine light went off.
Old Nov 4, 2004 | 11:39 AM
JDM_Type-R's Avatar
Default Re: help!!! check engine light went off (ebelp)
yea it came on..my fault
and yea its a high flow carsound cat
Old Nov 4, 2004 | 12:19 PM
ebelp's Avatar
Do you know which model Carsound you have? Is it 2.5"?
Old Nov 4, 2004 | 12:23 PM
skafia's Avatar
25 Year Member
Take out your bulb.
Old Nov 4, 2004 | 12:33 PM
AssPenny's Avatar
Default Re: help!!! check engine light went off (skafia)
Make one of these:
I believe Black R was making plug in and play versions of these. Don't know if he's doing it any more.
Old Nov 4, 2004 | 01:05 PM
ebelp's Avatar
Default Re: help!!! check engine light went off (AssPenny)
Homemade o2 simulator? I don't have the ***** to start cutting wires on my ecu.
Old Nov 4, 2004 | 01:20 PM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia &raquo;</TD></TR><TR><TD CLASS="quote">Take out your bulb.</TD></TR></TABLE>
dats what I did a long time ago. I'll only reinstall the bulb when VTEC wont engage.. which has been never so far.
Old Nov 4, 2004 | 01:21 PM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">Homemade o2 simulator? I don't have the ***** to start cutting wires on my ecu. </TD></TR></TABLE>
that's the wiring after the O2 plug, between the plug and the sensor, not the ecu wiring.
Old Nov 4, 2004 | 03:37 PM
JDM_Type-R's Avatar
Default Re: help!!! check engine light went off (Dave-ROR)
yea its 2.5..i guess ill just take the bulb out for now..or just leave it be..who knows
Old Nov 4, 2004 | 03:53 PM
nightrider's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Type-R &raquo;</TD></TR><TR><TD CLASS="quote">yea its 2.5..i guess ill just take the bulb out for now..or just leave it be..who knows</TD></TR></TABLE>
if you take the light bulb out, there may be other codes being thrown later so just check your codes every month or so.
Old Nov 4, 2004 | 03:54 PM
Chris F's Avatar
That's the first thing I saw too.. I was gonna reply "Congratulations!!!"
Usually, driving on the CEL isn't bad. Don't push it until you know what it is.
Old Nov 5, 2004 | 03:23 PM
PrettyLude's Avatar
make the home made o2 sim or go buy one, that **** is gonna eat up ur gas mileage
Old Nov 5, 2004 | 03:58 PM
Willard's Avatar
Default Re: help!!! check engine light went off (yoshi234)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoshi234 &raquo;</TD></TR><TR><TD CLASS="quote">i'm driving w/ #67</TD></TR></TABLE>
as am I.
but today the car failed ODB2 inspection b/c of the light.
POS cats.
Old Nov 12, 2004 | 05:25 PM
JDM_Type-R's Avatar
Default Re: help!!! check engine light went off (Willard)
UPDATE
today for some reason the check engine light decides to turn off...and i didnt do anything.
yipee.com
Old Nov 12, 2004 | 05:55 PM
B2FiNiTY's Avatar
It will probably come on again.
