idle adjustments
Old Nov 3, 2004 | 09:00 PM
JohnnyLux's Avatar
Default idle adjustments
my car seems like it idles high after its warmed up, it idles at 1000. is this normal for a d15b1 or should i adjust it. and if i need to adjust how do i go about doing this. thanks
Old Nov 3, 2004 | 11:22 PM
drussell4801's Avatar
Default Re: idle adjustments (civic90)
does your idle ever jump around, or does it ever start increasing for no apparent reason?
Old Nov 4, 2004 | 07:30 PM
JohnnyLux's Avatar
Default Re: idle adjustments (drussell4801)
no it stays fairly steady i just installed a crx cluster so i dont really know what its been doing all the time i just noticed that my idle seems high and that when im in 5th gear at 60 im at 3000rpm
Old Nov 4, 2004 | 08:34 PM
you're probably fine
if you have any driveability problems or fail an emissions test, then look into it further..
until then just let it go. If there is something wrong the problem will only get worse and then you'll know for sure what's up. Shouldn't be anything that will damage the motor in any way..
btw, no creeping idle usually = no vacuum leaks, so you're good on that.
my crx idles at 1000rpm.
Old Nov 4, 2004 | 08:35 PM
JohnnyLux's Avatar
cool thanks alot i just wasnt sure if that was allright but it is thanks alot!
victor.m
Sep 7, 2008 12:59 PM
UNKNOWN_MEMBER
Apr 20, 2005 12:39 AM
speedfanatic88
15
Aug 23, 2004 03:12 PM
raene
Dec 23, 2002 10:49 AM
raene
Nov 7, 2002 08:21 PM
