code 15 ignition output signal????????????
Old Nov 3, 2004 | 08:59 PM
all_motoref9's Avatar
Default code 15 ignition output signal????????????
wasup guys need help i have a code 15 its ignition output signal. what happened i was doing a compreesion test on my ls/vtec turbo so i took to ecu fusse out and did the test after the test put the fuse back in and the car doesnt want to start.when i checked all the fuses all are good.when i pull one spark plug wire from the distributor and try to turn on the car you see one big spark from the wire to the distributor then nothin else.what would caus e this this is the first time I seen this code
help me please!!!!!!!!!!!!!!!!
DESTROYDCB7
Jul 10, 2011 07:13 AM
jonathancrx
Mar 19, 2005 01:33 AM
EGJDM
Feb 5, 2005 12:27 PM
Charles B.
Mar 16, 2004 09:37 AM
CiViC SiR
Jun 26, 2003 07:07 AM
