oil leak problem
Old Nov 3, 2004 | 07:46 PM
SIRef9[831]'s Avatar
Default oil leak problem
hi everyone im now in here and i have a question for you.
i recently swaped a b16 into my ef and of course not every swap gose smoothly, i saw that i was leaking oil from under the car. i thought it was the axle seals so i changed them leaking would not stop. then i changed the oil pan gasket it still leaking. i checked the block no leakst there thank god. so i really dont know where its comming from. if anyone have any knowledge about this i would really need it right now.
Old Nov 3, 2004 | 07:52 PM
drdisco69's Avatar
Default Re: oil leak problem (SIRef9[831])
Remember: an oil leak never goes up, always down. Follow the oil up the motor and when it gets dry, thats where the leak is. Common ****: distributor o-ring, valve cover gasket, maybe a front main seal.
Old Nov 3, 2004 | 08:11 PM
ok so ill start from the top down. the thing is all the oil is comming from the driver side
Old Nov 3, 2004 | 08:15 PM
drdisco69's Avatar
Default Re: (SIRef9[831])
You'll probably have to take the timing belt cover off then. Could be a cam seal on that side, or the front main. Probably the cam seals.
Old Nov 4, 2004 | 08:22 PM
Default Re: (drdisco69)
yeah ill do that lets see how good of a job did these guys do with the cam intalation.
Old Nov 4, 2004 | 10:01 PM
anyone else? need help
Apr 2, 2013 07:58 AM
sho_shane
May 19, 2010 10:36 AM
coryfenton
14
Jun 10, 2009 10:20 PM
coryfenton
Jun 4, 2009 04:48 PM
CO_CReX
Jan 30, 2006 06:59 PM
