Oil breather canister/catch can question
I bought a block (used) and built it and put it in my car. The spot for the oil breather canister had been plugged so when I changed all the stuff over from my old motor I just left the canister off. I plugged the line coming from the intake manifold going down there after the pcv valve. Did I do the right thing and should I install a catch can? I'm mainly worried about the line going to the pcv valve.
You really should have something to vent the crank case whether it be the stock system, a catch can, or even just a breather filter with the PCV valve removed.
So should I connect a catch can between the valve cover and intake manifold and remove the pcv valve?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deckedlude »</TD></TR><TR><TD CLASS="quote">a catch can is nice but really isnt necessary. you could just run an open line off the cover and let it release like that. </TD></TR></TABLE>
Agreed, but I'd put a filter on it though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMinSi2000 »</TD></TR><TR><TD CLASS="quote">So should I connect a catch can between the valve cover and intake manifold and remove the pcv valve?</TD></TR></TABLE>
I'm rather sure that if you take out the PCV valve w/ that setup you'll be pressurizing your crankcase when you get into boost conditions.
I have my intake manifold capped, running the PCV valve to a catch can, and have a filter on the breather hole in the valve cover. Not the best solution, but should relieve any crankcase pressure OK.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB »</TD></TR><TR><TD CLASS="quote">
I have my intake manifold capped, running the PCV valve to a catch can, and have a filter on the breather hole in the valve cover. Not the best solution, but should relieve any crankcase pressure OK.</TD></TR></TABLE>
If you are running a turbo then you are pressurizing your crank case, the Honda PCV valve was never meant to see boost, that's why it closes when there is positive pressure in the intake.
93egallmotor
Apr 21, 2007 01:45 PM
