B18c5 swap into EK 98 need help
Old Nov 3, 2004 | 06:59 PM
CHAMPwhteEK's Avatar
Default B18c5 swap into EK 98 need help
all i want to know is what else i need for the sswap. already got complete motor and SI engine mounts. what else do i need for the swap
Old Nov 3, 2004 | 07:12 PM
Mag00n's Avatar
Default Re: B18c5 swap into EK 98 need help (CHAMPwhteEK)
Axles?..Shift linkage? ECU? Sounds like you need to search brah.
Old Nov 3, 2004 | 07:18 PM
Default Re: B18c5 swap into EK 98 need help (Mag00n)
i have the FULL swap axles,ecu tranny block head everything...just need to know what i need to expect to change with this swap my model hatch is DX
Old Nov 3, 2004 | 07:28 PM
smithenhiven's Avatar
11:11
Is your hatch an auto? If so you'll need a 5 speed pedal assembly. But yeah, I'd say that you need to search around a bit more before you attempt this.
eclypzex's Avatar
Default Re: B18c5 swap into EK 98 need help (smithenhiven)
brackets to hold the motor?
Old Nov 3, 2004 | 07:33 PM
Default Re: B18c5 swap into EK 98 need help (eclypzex)
my boy is gonna swap it but hes not gonna be back til lthe weekend so i need to get all the other hardware for the swap. it is stick... im not sure but am i suppost to use GSR L brackets or what... any help would be appreciated
Old Nov 4, 2004 | 03:44 AM
96BlackHB's Avatar
see the links in my signature. please search before you post....this is a fairly common question.
diversity210
35
Jun 13, 2010 07:07 AM
Castillo847
Oct 3, 2009 06:42 PM
smooth95
Aug 18, 2006 08:18 PM
civicrtype
11
Dec 15, 2002 09:15 PM
