? for those that have ITR rear LCAs on an EG
sure, JDM LCAs or ITR will work with the ITR sway bar....had it on my EF, now have it on my EG....
you can use the ITR bar with USDM LCAs as well (longest they have provisions for the sway bar)....
since the endlinks are all the same...mounts points do not change, why would there be a difference
Anyone else know? I'm trying to find out what parts I need to complete this:
'92 Civic H/B Si
ITR LCA's
GSR rear sway bar
Thanks. Tom
'92 Civic H/B Si
ITR LCA's
GSR rear sway bar
Thanks. Tom
Ok I should have searched this one more before I asked but here's one of the treads that helped me out:
https://honda-tech.com/zerothread?id=70453
I'm going to get the beaks kit, Fastbrakes has them. That thread has just about everything you need to know. Thanks guys.
Thanks. Only one thing, Will the beaks kit work the same for a GSR sway bar instead of the ITR one. I'm asking 'cause that's what I already have.
Thanks. Tom
Thanks. Tom
If your using the GSR bar I think you'll be safe using the factory brackets. You need something like the Beaks kit for the bigger bars that will tear the subframe (ITR).
JimmyL: Sell that crappy GSR bar and save up for the ITR bar. It's well worth it... believe me. The ITR bar will make your car lean a lot less and feel a lot more solid.
One more thing, I'm using the Beaks kit and the Prothane kit for added protection.
[Modified by ESCALVANTE, 11:18 AM 12/30/2001]
If you do the ITR rear swaybar, I HIGHLY recommend having some kind of front swaybar on too. If not, just having a huge 22mm rear bar will make a dangerous car on the street because it will swap ends with little warning.
dj theoretic
Suspension & Brakes
Dec 17, 2008 05:35 AM
